Could this work? Composite switcher as component video only switcher? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-29-2012, 10:46 PM - Thread Starter
theslydog's Avatar
I am currently OS at a relos place and need a common garden variety component switcher for a TV with not enough component inputs. The only problem is over here the parts locally are ridiculously expensive - if you can find them. I will not be here long enough to bother to get one sent over from the US.
Then I hand a thought...
What if I used 2 relatively cheap composite switchers (can get them here). One for the component video and the other for audio. Its a bit messy as you would have to switch 2 switches each time but it should work by using - video, L & R audio as say Y, Pb, & Pr on one switch box and the other switch box just for audio.
Has anyone tried this?
Could some kind soul try it out? Only need to try the component side as the audio is un changed.
I do not want to buy the switch boxes here only to find it does not work.
tsd
theslydog is offline
post #2 of 3 Old 12-30-2012, 12:19 AM
jautor's Avatar
Quoted: 1307 Post(s)
Liked: 836
Simple manual switches should work fine... Even electronic switching ones are going to be simply making connections which shouldn't be bothered by the signal type.
That said, why not an international shipper via eBay (or find one local using the same)?
http://www.ebay.com/itm/NEW-Remote-Component-Video-Digital-or-Stereo-Audio-RCA-Selector-Switch-Switcher-/271064236584?pt=US_Splitters_Combiners&hash=item3f1cb00228
Hard to beat $20, even if shipping is another $20 (an estimate using their shipping rates to Europe, since you don't say where you're at)
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
post #3 of 3 Old 12-30-2012, 06:29 AM - Thread Starter
theslydog's Avatar
I was even trying to go lower tech than that. One of those non-powered ones with push buttons on the front.
Im in Japan and have just found some 2nd hand ones on yahoo auctions. Just trying to work how set up an account and bid.
They are 1/2 the price of amazon japan.
http://g-ec2.images-amazon.com/images/G/09/ciu/a0/e0/c15a31e29fa0c516e8235110.L.jpg
http://ec2.images-amazon.com/images/I/413AM488VJL.jpg
