Home Theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-31-2012, 03:16 PM - Thread Starter
semschaf's Avatar
Please help! I am in the process of choosing equipment for a home theater/entertainment area. It will be used for 80 percent movies, 20 percent music. I am not an audiophile but would like the system to sound good. The room is 17x45x13. The couch is about 14 feet from the tv which is mounted over a fireplace. My budget is $6000-$10000. I was considering def tech mythos 10 for lcr, gem xl x4 for surrounds, 2 Hsu VTF-15h subwoofers, and denon 4311 receiver. I have grown skeptical of the on walls but I am limited with center channel options due to the tv mounting. Please give any ideas as to what you would suggest. I am open to on walls and floor standing, although my wife would prefer on walls. Thanks
semschaf is offline
post #2 of 4 Old 12-31-2012, 04:39 PM
Neurorad's Avatar
Quoted: 232 Post(s)
Liked: 145
Beautiful room.
You can get (relatively) high quality L-C-R speakers that attach to the TV and mount, that are aesthetically pleasing. Blend in nicely. Look at Leon and Bay Audio.
Surround sound in that room is a challenge.
Cables run already, for any speakers and hidden equipment?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 4 Old 01-01-2013, 08:40 AM - Thread Starter
semschaf's Avatar
Thanks for the reply. Yes the cables are run.
semschaf is offline
post #4 of 4 Old 01-01-2013, 10:11 AM
Neurorad's Avatar
Quoted: 232 Post(s)
Liked: 145
You may want a couple speakers above the bar too, maybe replicating the L-R channels, and for music.
Maybe 2 controllers/remotes, too.
I'd splurge on the LCR speakers, and go cheaper on the surrounds.
Neurorad is offline
