Need to know what they are or how they are made - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-02-2013, 09:29 AM - Thread Starter
Lepus's Avatar
I've been trying to search for some decorative columns which stick out by an inch or two are called, to help hide some wiring. Or are they just made? Any help would be appreciated.
Lepus is offline
post #2 of 3 Old 01-02-2013, 09:40 AM
hakstone's Avatar
Try searching wire channels. they usually go on floor, but I'm sure you find wall mounts.
hakstone is offline
post #3 of 3 Old 01-02-2013, 10:15 AM
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
Wiremold is a brand name; check HD/Lowes. Surface mount wiring/cable duct would be another name. Slotted wiring duct is also called finger channel. In/behind the wall looks nicer, but you gotta do what you gotta do.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
