Options for a Combination Game Room / HT with a large window and 1-2 doors - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 01-08-2013, 11:17 PM - Thread Starter
ToHellWithUGA's Avatar
So, I'm thinking about doing RSIC-V clips and furring channel, (at least on the ceiling), one OSB layer, green glue, and 5/8" drywall. However, I'm having a hard time finding a source for the channel. Any idea if this stuff from Home Depot would work?
http://www.homedepot.com/h_d1/N-5yc1v/R-202092934/h_d2/ProductDisplay?catalogId=10053
Otherwise, does anyone know of a source around Forsyth county, GA? Or a good source online?
ToHellWithUGA is offline
Old 01-09-2013, 08:00 AM
Kamikaze13's Avatar
Quoted: 104 Post(s)
Liked: 49
Furring channel is actually different. Do a search for resilient bar. I got mine from a drywall supply company.
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is offline
Old 01-09-2013, 08:08 AM
bepperb's Avatar
I'm just finishing up drywall and in a somewhat similar situation as I have 3 kids and just want to be able to watch a movie in the basement after they go to sleep without straining to hear what's going on. I have some limitations you don't, my joists were only 7'4" off the floor and my budget is pretty thin. But I'll share what I've done and hopefully it helps. For me clips were out of the question due to budget, height, and the fact that a lot of noise would just work it's way up the stairs anyway.
So what I did was R19 fiberglass between the joists and to be honest I was pretty disappointed in it. One could still easily hear any conversation upstairs. Still, for under 100 bucks for 600 square feet it's tough to complain. I then went and got generic resilient channel (http://menards.com/main/building-materials/metal-framing/2-1-2-x-12-double-leg-resilient-channel-25-ga/p-1708115-c-5695.htm) and added that and a single layer of 1/2 drywall and I'm fairly happy with the results, and the cost was so low if it didn't work I was out nothing. But I am happy with the results now that it's done, and the weak link now would be other paths for sound (mainly the staircase and interior grade door at the top). At this point TV with a normal volume cannot be heard upstairs but I'm sure "movie volume" will be a different story but part of the compromise.
If I had to do this all over again I might consider green glue instead, but the channel was about 100 bucks for 600 sq ft and the green glue plus another layer of drywall would have been well over 500, plus the added labor. Another thing that turned me off to that option was the fact that on their website they recommend channel in addition to gg for footfall traffic because GG doesn't isolate impact transmission well. Lastly, I can always go back and add a second layer later on if need be, but I can never add the channel again.
It is unfortunate that sound deadening drywall is so expensive. I was quoted 66 dollars for each 4x8 sheet. At half that I would have been all in.
As for your layout concerns I would put 48" french doors at the opening of the room and leave the stairs open. It's awkward at best if the doors are anywhere within 4 feet of the last step, bordering on creepy secret passage weird with doors on each end.
bepperb is offline
Old 01-09-2013, 09:11 AM - Thread Starter
Thanks again for the replies, guys. I will try to find a drywall supplier who sells to the public. I had thought about doing just the resilient channel, but had read some negative things about it (mostly on these forums). But the price definitely seems right (if I can find it at a similar price). Glad to hear about others who have used it and are pretty happy with it.
Good point. I guess I could get the channel and one layer of drywall up and see how it sounds. I was leaning towards making my bottom layer out of plywood, though.
So, are you recommending that I move the door into the room a bit? I had planned to do this (this may be what you were saying):
Old 01-09-2013, 09:48 AM
bepperb's Avatar
I would do what is in the picture above. In the original post it sounded like you were going to put the door at the bottom of the stairs, not the entrance of the room and I would avoid that completely. Assuming you can fit the projector above the window and get some good light blocking that's probably what I would do. It's not popular here but if you keep your components on the screen wall having all that room under the steps to run cable/fiddle with things will be great and despite having all those annoying lights that's probably where I'd do a builtin media cab.
On a side wall between my couch and the screen I have 60" glass french doors, interior style. You can easily hear speech from one room to the next, but it does make a huge difference to have the door closed, I suppose like any other interior door. I have not gone to any effort to get rid of the 1" gap at the bottom of the door or the 3/8" or so gap between them because it doesn't really matter in our situation. But even if they only stop half the sound there's still another door and dead space between that and the downstairs bedroom/upstairs. I guess you could consider exterior french doors if you're really going to turn it up.
I can see all the problems with the resilient channel. It's not hard to avoid short circuiting the screws into the joists but it is one more thing to consider the entire time and it does slow you down some. I was not able to get away with 3/4" screws which would eliminate that problem completely, they would flex the metal and not bite most of the time. It probably isn't as good of a solution as ones that cost five times as much. But the price and depth of install (1/2" additional) was hard to ignore. I spent less than 300 bucks between them, insulation, screws and it was well worth the expense. If you do more in the media room do at least this in the bedroom/gym/etc.
bepperb is offline
Old 01-09-2013, 01:53 PM - Thread Starter
Well, I found a place that carries the RC1 locally, but has to special order the RC2. The RC1 looks kind of scary (one legged channel), not sure I even want to use it on the walls. Anyone have experience with this? Or should I use RC2 everywhere?
Old 01-11-2013, 09:35 AM
bepperb's Avatar
Once you start using it you will feel much more comfortable, I felt the same way when I brought it home. I could only find two legged RC2 so that's what I used, but I only screwed one side down. I don't think you'll have a problem using RC1. It does flex, that's how it works, but it wasn't very challenging to use. Make sure to use fine threaded drywall screws, I preferred the 1"ers. I did 16" on center, I know one is supposed to do 24" for best noise reduction but I don't need a drywall panel falling on my kids.
bepperb is offline
Old 01-11-2013, 10:35 AM
Kamikaze13's Avatar
Quoted: 104 Post(s)
Liked: 49
I also used 1" fine thread drywall screws with no problems.
Old 04-29-2013, 09:23 AM - Thread Starter
Hey guys. Long time no post (as usual).
I'm making progress (slowly) on finishing my basement. I have the bedroom electrical finished, hvac run, and sheetrock hung. The bathroom is wired and sheetocked, plus tile backerboard, rough-in plumbing done, exhaust and hvac, and tub set. I have the hvac ductwork and indoor/outdoor systems in place (2.5 ton heat pump), and should be starting it up this week (if I can finally get my uncle to help me braze the connections and get it started up). I have the kitchen lighting done, and am running the outlets now.
We have decided that I should move my office from the main floor of the home to the basement where the gym was going to be. My current office will become a toy room / baby jail for the twins (we have nowhere to "contain" them on the main floor at the moment, and it is NOT working).
Anyway, I am still trying to decide what to do about the media/HT/game room. I'm looking at (yet another) compromise where I use a dropdown screen in front of the window, and either leave the opening at the bottom of the stairs open (and just use heavy curtains when viewing), or put a large door/doors that would allow free flow between the rooms.
So, I edited my layout shown above to reflect this.I don't like it as much, but it seems to be the best compromise and use of our space.
Assuming I had to go with this layout, I have some questions:
- Would it help if I moved the door to the workshop closer to the center of the wall, so that I can mount side-surrounds at the same level on both sides? Or, I could just go above the door and keep everything high (the opening at the bottom of the stairs is probably going to push the side surrounds too far forward in the room, but oh well))
- If we didn't have a door to the room, and just used heavy curtains, would it even be worth the trouble to use clips/channel/DD/etc. everywhere else? I'm thinking of doing it 'just in case' I am able to make this room into a proper HT one day...
Any comment / advice / ridicule?
