Wall mount question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-02-2013, 09:16 PM - Thread Starter
mpivovar's Avatar
I posted this earlier in a tv thread but figure this is a better place to ask the question. I plan on mounting an 80 inch tv with the Sanus VMPL3. The question I have is when I attach the TV to the mounting arms can you use different holes in the arms to have the TV sit higher or lower. As an example if the mounting bracket is lag bolted on the wall and in the future I want to lower or Raise the TV a couple of inches can I do it by just moving the TV up and down in the different holes on the arms and not having to take the plate off the wall to re lag bolt it up or down. Thanks?
mpivovar is offline
