Banana plugs question? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 40 Old 01-15-2013, 03:39 PM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
Thanks alot for the feedback guys, i've connected all the cables now as shown in the pictures below.
As you can see my speakers have 4 places where i can attach the wire.
I take it that the bottom 2 are for bi-wiring??
Is there any significance for bi-wiring, from what i've read on wikipedia some say it differs highs and lows others say it's just a gimmick??
Can the difference be appreciated??
My center doesn't have that option, just the front and the rear do.
geronemo3 is offline
post #32 of 40 Old 01-15-2013, 03:59 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Yeah, don't bother... The theory behind it is sketchy at best.
jautor is online now
post #33 of 40 Old 01-15-2013, 04:21 PM
Chris DeWitt's Avatar
The type of plug you purchased are made for 90 degree mounting. You wanted the closed style plug for 180 degree mounting. Two different plugs, two different applications.
geronemo3 likes this.
Chris DeWitt is offline
post #34 of 40 Old 01-16-2013, 05:48 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Where did you buy those plugs?
Is the hole at the rear of the plug a connection for another banana plug?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #35 of 40 Old 01-16-2013, 05:53 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
This is Sewell's how-to, using rear and side (180 and 90):
http://sewelldirect.com/articles/how-to-use-banana-plugs-with-speaker-wire.aspx
For 180, it looks like the individual strands fan out, after the rear plug is inserted.
I think the plugs you have could be used either 180 or 90 - but I've honestly never used banana plugs.
Neurorad is offline
post #36 of 40 Old 01-17-2013, 12:42 AM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
The ones i have can only be used at 90 because of the way the screw is constructed, using them at 180 is just crushing the wire.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=9437&seq=1&format=2&ref=cj
These are the ones i have, "Jautor" recommended me these and i am happy with them.
post #37 of 40 Old 01-17-2013, 05:26 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Sewell's 'how-to' page, linked above, shows a similar 'open screw' type plug, connected in the '180' config.
Since you're pleased with what you have, I'm just posting this for posterity.
Neurorad is offline
post #38 of 40 Old 01-17-2013, 06:46 AM
Lepus's Avatar
The four posts in the picture or for bi wiring. I believe one goes for the mids and highs others for the bass response. The metal plate between them means it will use a single input from the receiver.
Lepus is offline
post #39 of 40 Old 01-27-2013, 12:53 AM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
Thanks for that link, those plugs are pretty identical to mine, right now I have attached the wire at 90 degree because I felt that way the banana plug was holding the wire better as compared to 90 degree.
Some plugs actually have some room to fan out the cable properly instead of just crushing it, if I get another smaller system for another room next yr. i might use those.
post #40 of 40 Old 01-27-2013, 06:07 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
IIRC, the Monoprice product page for those banana plugs included a Review which mentioned removing the black and red plastic markers/washers, to allow more room for fanning of conductor threads.
Neurorad is offline
