New Basement Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-08-2013, 05:43 PM - Thread Starter
shocka43's Avatar
Long time lurker, first time poster....
I have a few questions regarding a receiver that will meet my needs in my basement project...here is the setup, I need assistance in selecting the proper receiver...
I will have a main viewing wall with 3 HDTV's. Two will be connected in some fashion to Direct receivers (TV's 1 &2). The third (TV 3) will be a standalone with an on air HD antenna for local games, etc..
I will have a 4th HDTV centered at the bar (TV 4), in a side area, this will also be a connected to a Direct receiver.
I plan on having the main viewing area set up as my primary zone with 5.1 surround.
I plan on having the bar TV with my second zone audio.
Questions...
Is there a receiver that will accept multiple HDMI (Direct) inputs and separate that simultaneously into TV 1 and zone 1 audio and TV 4 and zone 2 audio? Basically...Two games and two audio feeds...2 direct boxes to two different tv's, one to zone 1 and one to zone 2 audio, through the receiver.
Next...on the main viewing area...is it possible to switch audio from TV 1 to TV 2 in zone 1...say during a big play or during a commercial...I can switch the audio from what is on TV 1 to TV 2 while maintaining the picture on TV 1? I guess that would be switching audio with the other continuing to run with pass through video.
I am sorry if this is clear as mud and I swear I am not as clueless on what I want to do as this sounds. Just haven't shopped around the new switching capabilities for a few years.
Thanks for any assistance!!!!!
shocka43 is offline
post #2 of 6 Old 01-08-2013, 06:01 PM
J Real's Avatar
Nothing can do what youre asking.
J Real is offline
post #3 of 6 Old 01-08-2013, 06:06 PM - Thread Starter
shocka43's Avatar
So is there a receiver that can run video and audio to zone 1 and a separate video and audio to zone 2?
Or is my only solution to get two separate receivers?
shocka43 is offline
post #4 of 6 Old 01-08-2013, 09:52 PM
IHaveAMullet's Avatar
I wouldn't think you would need two separate receivers. How about a HDMI splitter to zone 2, one to tv (video) and one to the reciever (audio). As I understand most receivers with 2 zone capability will play A&V on zone 1 with separate audio on zone 2.
IHaveAMullet is offline
post #5 of 6 Old 01-10-2013, 05:27 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
I think this receiver might be able do it : http://www.amazon.com/Marantz-AV8801-Home-Theater-Preamplifier/dp/B00A203I0W
Probably should ask this question in the receivers forum.
This would probably be the most economical solution.
David
crussader is offline
post #6 of 6 Old 01-10-2013, 06:51 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
An HDMI 4x4 matrix switch to run the displays, and an AVR with zone2 capabilities. Although are you really going to have the audio in the bar different than the primary if they're in the same room?
You then run audio outputs from each of your sources (DirecTV boxes, digital / analog audio from the TV tuner to get OTA audio) to the AVR - this is separate from HDMI. Now you can switch the audio separately from the video. The only limitation is that you'll be limited to DD5.1 audio - only an issue for Blu-ray, and only then if you care about DTS-MA support...
Jeff
jautor is offline
