Need Paradigm ADP-170 replacement drivers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-11-2013, 03:05 PM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 34
I have a set of Paradigm ADP-170 surrounds. One of the drivers in each speaker has deteriorated and is coming apart. Can I replace them with drivers from somewhere like parts-express without issue? If it's OK, I would probably replace all four drivers. I don't really want to spend a lot on new surrounds.
sslv2pwned is offline
post #2 of 6 Old 01-11-2013, 03:19 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Better asked in the speaker forum, but why wouldn't you contact Paradigm about buying replacement drivers directly from them that are the correct ones?
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 6 Old 01-11-2013, 06:46 PM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 34
I figured they would be a lot more expensive, but I'll give that a try.
post #4 of 6 Old 01-11-2013, 09:06 PM
jautor's Avatar
Liked: 852
Ummm... The driver is the speaker, right? You have a nice speaker - replacing it with a cheap driver instead of the correct one, turns it into a cheap speaker. And it won't match the other one (sonic-wise). Worse, this is a dipole.
jautor is offline
post #5 of 6 Old 01-15-2013, 08:58 AM
bepperb's Avatar
Paradigm shipped me a new tweeter diaphragm a few months ago. The price wasn't bad at about 30 bucks. They were nice to deal with, and knew what they were doing. Shoot them an email and they'll give you a price and you can go from there.
bepperb is offline
post #6 of 6 Old 01-15-2013, 09:12 AM
Lepus's Avatar
I was missing some screws from one of the boxes and they sent them to me no problem. I would say they are good at backing their product.
Lepus is offline
