connect projector ? - AVS Forum | Home Theater Discussions And Reviews
Old 01-14-2013, 10:57 AM - Thread Starter
jinxjx's Avatar
Hi there, dont know if this is the right place to post but a friend of mine wants to connect his modern pc to a OKYO TX SR309AV Receiver , then from the reciever to a knoll HD 110 celing projector. can this be done? And what cables would be needed......thank you biggrin.gif
Reciever
Projector
jinxjx is offline
Old 01-14-2013, 12:43 PM
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
Does his PC have HDMI out on it?
If so he could connect his PC to the receiver via HDMI, then use Component cables (the ones that are green, red, and blue with white and red audio) to connect the receiver to the projector.
Or if looks like he could possibly do VGA out to the projector, and if his PC can output sound via optical he can connect the PC to the receiver via optical cable for sound only.
purbeast is offline
Old 01-14-2013, 01:06 PM - Thread Starter
jinxjx's Avatar
yes he has nvidia gt 640, which has mini hdmi, dvi-d and dvi-i....thanks
jinxjx is offline
Old 01-14-2013, 05:14 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Originally Posted by purbeast View Post
Does his PC have HDMI out on it? If so he could connect his PC to the receiver via HDMI, then use Component cables (the ones that are green, red, and blue with white and red audio) to connect the receiver to the projector.
Well, no you can't do that... HDMI sources will not output via Component from an AVR.
But the projector has DVI in, so an HDMI-to-DVI cable would allow HDMI source if they are not using HDCP copy protection. (I doubt the projector has HDCP built-in) So that will work fine for connecting the PC, but if he has other HDMI devices (DVD/BD player, etc) I don't think that'll work...
Jeff
jautor is online now
Old 01-14-2013, 05:50 PM
jdanforth's Avatar
Liked: 25
HDMI to DVI cable from PC to Projector: http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10231 (As Jautor correctly pointed out this will NOT pass copy-protected content)
Toslink (fiber optic) cable from PC to Receiver: http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10229
If computer lacks toslink output then USB to SPDIF converter gizmo: http://www.turtlebeach.com/product-detail/sound-cards-accessories/micro-ii/31
Or if surround sound isn't important use a headphone to RCA cable (stereo sound only): http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
jdanforth is offline
Old 01-15-2013, 07:44 AM
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
Jeff
Ah okay I was not aware of that!
purbeast is offline
