Optical cable vs HDMI?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 61 Old 01-14-2013, 07:23 PM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
Hi,
I am trying to understand which audio signal is better.
My LED TV has a Optical out and my receiver has an optical in.
I have Pioneer VSX-1021 receiver
TV is Samsung UN55D5000 LED TV
Now is it better to connect my Xbox, DVR to my TV through HDMI and than send the audio signal via Optical cable to receiver to play through sound system.
By this setup i can mute the tv volume and switch on the receiver for surround sound or if i don't want to use the receiver, i can turn it off and use the TV volume to play sound.
Or
Should the HDMI out of xbox and DVR be connected to receiver HDMI in and than receiver HDMI out to TV HDMI in.
Basically i am trying to ask the different in these 2 setups.
geronemo3 is offline
post #2 of 61 Old 01-14-2013, 07:29 PM
jautor's Avatar
Quoted: 1330 Post(s)
Liked: 852
For those sources, or really for anything (currently) except Blu-ray or devices playing back BD content (from a server, for example), there should be no difference. Those sources will be producing, at best, DD5.1 content, which will be identical over optical digital or HDMI. (ok, if you play a DVD through the Xbox, you could get a DTS soundtrack, which would not likely be passed through the TV - yet).
Blu-ray will have the advanced HD audio codecs (DTS-MA and Dolby Digital Plus), which cannot be passed over the optical digital cable, and so there will be an audio performance difference vs a direct HDMI connection to the receiver.
Now, hooking everything through the TV does mean you have to ensure the TV supports DD5.1 over HDMI, and that it properly passes audio received from HDMI back out its optical output. As long as it does that, do whichever path works best for you from a usability standpoint. If you want to sometimes use your TV speakers, run the stuff through the TV.
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 61 Old 01-14-2013, 09:26 PM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
Jeff
Wow....thanks for the quick reply.
I guess i will have to pull the TV manual out and educate myself as to whether my tv supports DD5.1 or no. smile.gif
post #4 of 61 Old 01-14-2013, 09:28 PM
jautor's Avatar
Liked: 852
Or just try it and see if your AVR lights up with DD vs. 2-channel PCM stereo...
jautor is offline
post #5 of 61 Old 01-15-2013, 04:14 AM
Lepus's Avatar
The tv does SRS tru surround. If I were you I would run everything to your receiver, and have a single HDMI to the TV, you will get the best sound that way. The only thing is, is that you have to always turn the receiver on. You would think optical would sound better, but HDMI is where all the new sound encodings work. Also optical supports only has 5.1 channels.
Lepus is offline
post #6 of 61 Old 01-15-2013, 02:29 PM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
Ok so i played videos from different sources to see how it turned out.
I played Dexter from the DVR (DVR to TV via HDMI and TV to receiver via Optical) it was playing in surround sound, it even said D Digital on the receiver. My main concern was that i do not want to keep my receiver on all the time, so i think this takes care of that since i am getting Digital sound over optical cable.
Now another thing i noticed and am confused about is that when i played a movie MKV format 1080p with 5.1 surround sound form my media server on the TV (the TV has LAN input to it's connected to my network) it played in 5.1 Digital.
When i connected my laptop to either my receiver (via HDMI and than receiver to TV via HDMI) or laptop to TV (via HDMI and than TV to receiver via Optical) the same movie played is stereo only??
I don't have a blu-ray player so when i do get one in the future i will connect it to receiver to get the optimal sound.
post #7 of 61 Old 01-15-2013, 02:58 PM
jautor's Avatar
Liked: 852
Check the application and the control panel (audio settings) to make sure HDMI audio is set to something like "bitstream" or Dolby Digital... Very likely the playback application or the OS has defaulted to 2-channel stereo output for compatibility reasons.
Jeff
jautor is offline
post #8 of 61 Old 01-15-2013, 08:59 PM
jdanforth's Avatar
Liked: 25
Jeff
Yep... Bitstream is what you want here. It sounds to me like "PCM" is selected.
jdanforth is offline
post #9 of 61 Old 01-16-2013, 11:51 PM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
Check the application and the control panel (audio settings) to make sure HDMI audio istset to something like "bitstream" or Dolby Digital... Very likely the playback application or the OS has defaulted to 2-channel stereo output for compatibility reasons.
Jeff
Yup the OS and the app. both were outputting 2.1 channel audio.
First i had to go to sound settings and there my receiver was visible after connecting it with HDMI so i choose 5.1 although i only have a 5 speaker setup with no sub. After doing this the receiver display changed from stereo to PCM.
secondly in KM player i had to choose 5 channel speaker output in "internal audio decoder setup"
Like i mentioned above it was stereo, after changing settings in sound playback and configuring to 5.1 it become PCM.
Now what is PCM audio?? it is playing 5.1 surround to how is it diff the 5.1 surround??
Thanks guys.
post #10 of 61 Old 01-17-2013, 05:38 AM
Lepus's Avatar
PCM is non-compressed audio, and only outputs stereo (2 channel audio). Dolby Digital is compressed and is capable of providing 5.1
Lepus is offline
post #11 of 61 Old 01-17-2013, 07:41 AM
jautor's Avatar
Liked: 852
The PC may be doing the Dolby decode and outputting 5.1 LPCM over HDMI. It usually doesn't matter if the source (PC / Blu-ray player) does the decode, as long as you're getting five channels. But if you're going to run HDMI to the TV and then digital audio back to the AVR, you'll have to have the source send the encoded DD5.1 stream. The digital audio cable will not support 5-channel LPCM.
Also, if you're not using a subwoofer, make sure your AVR speaker configuration has the subwoofer disabled. That way it will route the bass to the other channels.
Jeff
jautor is offline
post #12 of 61 Old 01-18-2013, 10:08 AM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
Jeff
Is this your line of work or hobby?
I will put up a screenshot of my setting to have a better idea.
thanks.
post #13 of 61 Old 01-26-2013, 11:46 PM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
Got busy with some stuff.
What you said is absolutely accurate.
Here's a screenshot of running the HDMI to receiver and receiver to TV
So you can see that my PC recognizes that receiver is 7.1 and although the display on receiver says PCM it is still giving me proper 5 channel surround.
Here's a screenshot with HDMI from PC to TV and optical running to receiver.
As you can see the PC is only recognizing the TV as stereo.
So the conclusion is that every time i want to attach my PC to TV i wil do it through receiver to get the 5 channel surround sound.
post #14 of 61 Old 12-04-2013, 11:24 AM
Michael Airhart's Avatar
Wouldn't you agree that most people only have a 5.1 setup. My receiver has 8.1 channels and I only use in a 5.1 configuration. Unfortunately my recover doesn't have HDMI options so I am limited to the use of an optical cable.  My sound quality is certainly fantastic the way it is I have 2 front 2 rear 1 center and a powered sub. If I were running the system in a very large house that warranted the use of all 8 channels then certainly I would need to upgrade to a unit with HDMI in and out. For someone who has the option either way though I would agree that HDMI would definitely be the way to go.
Michael Airhart is offline
post #15 of 61 Old 12-04-2013, 11:26 AM
Recover should be receiver. Sorry for the typo.
post #16 of 61 Old 02-14-2014, 09:43 AM
THeCozen1's Avatar
I have all sources (TWC box, Sony BDP-S590, ROKU) routed through my Yamaha RX-V473 via HDMI with 1 HDMI out from AVR to TV. This way, I was getting DD & DTS TRUE-HD sound to my 5.1 speakers.
Recently, the video drive in my AVR hit the skids and I'm getting a purple hue on all sources except the ROKU (weird).
I've now routed all sources (HDMI) through the TV and only use the AVR for audio. I'm just getting PCM...no more DD. If the HDMI handshake is an issue or the AVR video drive is fried, is there any benefit from routing everything back through the AVR via HDMI and use the optical in lieu of HDMI out to TV?
I really want to get the best sound from my equipment and all I get now is PCM. I don't want to ship my AVR from Raleigh to Charlotte, NC (under warranty) for a month when I know they'll probably not fix the problem or even be able to duplicate it.
Any help would be greatly appreciated. How much sound am I really losing between PCM and DD/DTS?
Panasonic 55VT50
Yamaha RX-V477
Energy Take Classic 5.1
Sony BDP-S590
ROKU 2XS; ROKU 3
TiVo Roamio Basic w/ Mohu Curve 30
THeCozen1 is offline
post #17 of 61 Old 02-14-2014, 11:41 AM
jautor's Avatar
Liked: 852
Check the setup menus in each of your sources for audio settings. They have probably been set (default) to PCM instead of DD / "Bitstream" for compatibility purposes. That should give you the best audio. Only source that really needs HDMI for the best audio is a Blu-ray player.
Lots. With PCM you're getting at best a matrixed Dolby Surround mix. DD5.1 will be a night-and-day difference...
Jeff
THeCozen1 likes this.
jautor is offline
post #18 of 61 Old 02-14-2014, 12:01 PM
THeCozen1's Avatar
Jeff
Thanks for prompt response. I had it all setup correctly before I couldn't route equipment straight thru AVR due to video issues. Set it from PCM to auto (only choice) and had to turn "BD Audio mix" off - whatever that is. That got me DD from each source. How do I get true sound if I don't route equipment thru AVR? I now have equip running thru TV first with the HDMI out from AVR to TV.
Panasonic 55VT50
Yamaha RX-V477
Sony BDP-S590
ROKU 2XS; ROKU 3
post #19 of 61 Old 02-14-2014, 12:59 PM
jautor's Avatar
Liked: 852
You run the separate optical / coax digital audio connections to the AVR from each source... In order to route this back through HDMI, a lot of support (rare) for ARC in both the TV and AVR is needed, and a lot of "if"s there.
jautor is offline
post #20 of 61 Old 02-14-2014, 07:37 PM
THeCozen1's Avatar
So I keep my equipment routed through the TV via HDMI and then connect the TV and BDP to the AVR via optical...correct?
Would I need to keep the HDMI out from AVR to TV at that point? I would think not if it weren't for the ROKU which is the only source not having video issues (purple hue over all content). If I keep the HDMI out connected to the TV (for DD thru ROKU), are there any conflicts w/ the opticals?
Thanks again buddy.
Panasonic 55VT50
Yamaha RX-V477
Sony BDP-S590
ROKU 2XS; ROKU 3
post #21 of 61 Old 02-14-2014, 10:46 PM
jautor's Avatar
Liked: 852
Yes.
Only if you keep the un-affected Roku running through the AVR.
No. You may have to configure the AVR to assign the optical inputs to a particular source (depends on the AVR)...
Jeff
jautor is offline
post #22 of 61 Old 02-15-2014, 07:23 AM
THeCozen1's Avatar
Just ordered the Mediabridge optical cables from Amazon for $5 each...thanks. Hope it works because shipping the Yamaha to Charlotte under warranty is not appealing. This is probably cheaper than shipping costs anyway.
Panasonic 55VT50
Yamaha RX-V477
Sony BDP-S590
ROKU 2XS; ROKU 3
post #23 of 61 Old 02-18-2014, 05:38 PM
THeCozen1's Avatar
Well good, because the BDP is the only source I can get the optical cable to work with my AVR. I'm now getting DD through this source as before.
For some reason, I can't get the cable box to output in DD with the optical. I've tried connecting both the TV and cable box through the AVR via optical and all I get is PCM. I think it must have something to do with ARC functions being enabled, but I could be completely off base here. When I unplugged the ARC HDMI cable while the optical was plugged into the TV, I got no sound whatsoever. I should have the cable box (not TV) connected to the AVR via optical, correct?
I may give it another try and turn off ARC functions while the optical is connected to the cable box to confirm. This isn't really an option because I want my TV and AVR to work together. Any additional thoughts would be appreciated.
Why do you think the BDP is the only source to be concerned with sound?
Panasonic 55VT50
Yamaha RX-V477
Sony BDP-S590
ROKU 2XS; ROKU 3
post #24 of 61 Old 02-18-2014, 06:35 PM
jautor's Avatar
Liked: 852
Yes.
Unless you're using "apps" built into the TV, you can just turn off ARC altogether. What do you mean by "work together". The remote control functions are HDMI CEC, not ARC. Regardless, turn all the extra stuff off until you figure out why you're not getting DD audio correctly.
It's a fact, not an opinion... No video provider (within reason) delivers anything better than DD5.1 currently, which is supported (along with DTS core) over the SPDIF / Toslink digital audio cable. Only Blu-ray content contains "advanced audio codecs" that exceed the specs of the SPDIF link - which is why you need HDMI for those devices.
Jeff
jautor is offline
post #25 of 61 Old 02-18-2014, 08:08 PM
THeCozen1's Avatar
By "work together", I guess I just meant remote control functionality.
After switching "HDMI Control" from the AVR setup menu off and on a few times, the ROKU content displayed as green. Turning the AVR off and on fixed the ROKU display which makes me wonder if I should reroute all sources back through the AVR via HDMI to see if the BDP and cable box are displaying properly again (previously had purple hue on content for both). Maybe turning HDMI Control off/on forces a handshake? I'm afraid I would just be back to a purple screen at some point.
The AVR video functions worked perfectly for the past year. Does any of this make since to you?
Thanks again for all the help.
Panasonic 55VT50
Yamaha RX-V477
Sony BDP-S590
ROKU 2XS; ROKU 3
post #26 of 61 Old 02-22-2014, 10:33 AM - Thread Starter
geronemo3's Avatar
Quoted: 32 Post(s)
Did u change the sound setting in DVR to surround sound from stereo.
post #27 of 61 Old 02-22-2014, 11:18 AM
THeCozen1's Avatar
My DVR only has one audio setting...digital.
After an hour or so of tinkering, I eventually got HDMI connections to work again with everything routed through my AVR. I think it may have been an AVR firmware update gone wrong. Either that or I'll have a purple hue on all content again soon.
At least the Alien BD from the Anthology was smokin last night. DTS HD Master via HDMI was a treat.
Thanks for posting.
Panasonic 55VT50
Yamaha RX-V477
Sony BDP-S590
ROKU 2XS; ROKU 3
post #28 of 61 Old 08-30-2014, 08:45 AM
Quoted: 17 Post(s)
Liked: 0
Yes.
Jeff
I have few question:
1. if I connect the TV with optical to resiver I will hear 5.1 DD sound Like as the source would plug with hdmi to resiver ?
2.If I always connect any source like Streame , PS3 etc and connect Optical from TV to resiver it would sound the best like Hdmi connect ?
3.If I connect PS3 with optical to RESIVER it will sound like If I will ps3 to TV with HDMI and then Connect Optical cable from TV to resiver It sound equall?
4.about the optical input on the resiver , I heard the Optical input don't support DD 5.1 OR DTS ETC , but if I connect My PS3 with Optical cable to resiver directly and I play GTV V (BLUE RAY DISK WITH DTS SOUND ) I will hear the sound on resiver or no sound or it will be converted to ac3 and I hear 2.1 stero instead 5.1 DD ?
5. the last question - I have LG tv ld 550 32inch , and ps3 connected with hdmi cable the bring me sound and picture as well , my tv has only 2 channel stero build in speaker , and how I although hear the ps3 games that have dts on tv that not support DTS Or blue ray soundtrack , it converted to AC3 because of that I sound the voice on TV when I play ?
thanks alot .
FredMin is offline
post #29 of 61 Old 08-30-2014, 09:07 AM
jautor's Avatar
Liked: 852
This will depend on the TV, and if your "source" is built into the TV, or is a device connected to it with HDMI. For built-in sources (antenna, Netflix or other 'streamer apps'), it will work fine.
The TV will probably limit the audio to DD5.1 at best, and may cause the source to drop to 2-channel stereo (no surround). For Blu-ray players with DTS-MA or other advanced audio, they must be connected to the receiver with HDMI.
Yes. Two things limit the digital audio - the audio support in the TV, and the capabilities of the digital optical (SPDIF) interface and cable. SPDIF only supports DD5.1 or 2-channel PCM stereo. The advanced audio formats of Blu-ray (DTS-MA, 5 or 7-channel PCM, etc.) cannot work over the optical output. If the TV only supports 'stereo' and not DD5.1 (which is only common on newer TV models), the HDMI audio will be downgraded to the format that the TV supports.
The optical input on your receiver should support both DD5.1 and DTS. But you won't get the Dolby Digital Plus or DTS-MA lossless audio from Blu-ray discs. Those are only supported by HDMI audio.
Sorry, I didn't understand the question - but the best way to connect all of these devices is to use HDMI and connect all sources to your receiver, and then use one HDMI cable to the TV.
Does your receiver have HDMI inputs? That will tell us which solution will be best for you.
Jeff
jautor is offline
post #30 of 61 Old 08-30-2014, 02:19 PM
Quoted: 17 Post(s)
Liked: 0
Jeff
Thanks alot for you help ,
I haven't receiver , I interest in beggining take a complete Home Theater like LG or Samsung Company like this :
http://www.samsung.com/us/video/home...r/HT-H5500W/ZA
but when I read that the optical input didnt pass true-hd and DTS HD-MASTER that is a problem .
If I play GTA V in PS3 that the GTA V is blue ray disk , and If he have DTS HD-MASTER soundtrack it will not through over optic input PS3-Receiver ? all PS3 games have Sound codec that not pass through optic input ?
-about question that I ask before , if PS3 connect with Hdmi to LG LD550 TV and I will then connect optic cable to receiver the same quality will reserved like the PS3 connect directly to Optic input to reciever?
because the TV can downgrade to stero audio when the ps3 connect to TV by hdmi and after that sound will pass through optic from TV to receiver it will be 2 channel stero and not dd5.1 ,am I right ?
I will be happy if you advise me What I should buy receiver with speaker or Complete home theater like LG or Samsung Company ( the only problem with that complete it has not hdmi input only output )
-another questions : All MKV movie files on the net and PS3 GAMES like GTV V and others have codec that can pass through Optic input ?
-In Cable Box on MTV LIVE HD HAVE RCA OR COAXIAL output . this will support all codec that the channel MTV LIVE HD cable box has streaming ?
Thanks alot .
Quote:Any help would be greatly appreciated. How much sound am I really losing between PCM and DD/DTS?
Jeff
about the red line that I marked , Someone that define in PS3 "bitstream" only get "DTS-ES Matrix" on Receiver instead "DTS-HD MA" and when it change to :LPCM he gets "DTS-HD MA" '
How can we explain that "LPCM" Better that "Bitsream" settings ?
FredMin is offline
