In-Wall Speaker Wire Gauge - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-17-2013, 03:15 PM - Thread Starter
Doogals's Avatar
Quoted: 61 Post(s)
Hoping that I can use the same gauge speaker wire for all of my runs, but confused about power being lost if the cable resistance/gauge is too high and what "ohm load" means. Based on the length of each run and speaker spec's below, what would you guys suggest? Appreciate any insight.
Center: 7.5'
Front Left: 15.5'
Front Right: 2' (This speaker is located above the AVR cabinet.)
Surround Left: 31'
Surround Right: 17.5'
Center Speaker:
Recommended Power: 10 – 80 Watts
Impedance: 8 Ohms nominal
Sensitivity: 86dB @ 1 Watt/1 meter
Tweeter: One 3/4" dome, video-shielded
Midrange: Dual 3" drivers, video-shielded
Front Left/Right:
Recommended Power: 10 – 120 watts
Sensitivity: 86dB @ 1 watt/1 meter
Frequency Response: 105Hz – 20kHz (–6dB)
Surround Left/Right:
Tweeter: One 1/2" dome, video-shielded
Midrange: One 3" driver, video-shielded
Doogals is offline
post #2 of 6 Old 01-17-2013, 03:45 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
None of those runs are long enough to be concerned about... Any wire will do. If you're buying a roll of in-wall cable (do buy in-wall rated CL2 cable for that purpose), the price difference from 16-gauge to something larger like 14-gauge is minimal (price delta on a Monoprice 100' spool is $6-8 as you move between 16/14/12 gauge. I wouldn't run anything smaller than 16-gauge, and if it'll make you feel better, use 14 or 12. biggrin.gif
Jeff
jautor is offline
post #3 of 6 Old 01-17-2013, 04:00 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
I would go with 12 gauge. Better safe than sorry. The cost difference is negligible. If someday you put a 4 ohm speaker on that 31' run, you don't want to have to switch the wire.
David
crussader is offline
post #4 of 6 Old 01-17-2013, 04:12 PM
jautor's Avatar
Liked: 777
Well, you wouldn't HAVE to switch the wire, but I agree, if you're putting it in-wall for one room, 12 AWG will remove any doubt. Certainly what I ran for my theater, with ~30 ft runs...
Great source for speaker wire info:
http://www.roger-russell.com/wire/wire.htm
Jeff
jautor is offline
post #5 of 6 Old 02-14-2013, 06:43 PM
ChrisHarrington's Avatar
Center: 7.5'
Front Left: 15.5'
Surround Left: 31'
Center Speaker:
Front Left/Right:
Use lamp cord.
Sent from my Galaxy Note 10.1 using Tapatalk HD
Samsung HL-67A750A1F | Pioneer VSX-1121-K | Energy Take Classic 5.0 | BIC America F12 | Xbox 360 Windows Media Center 7 | Belkin PureAV PF30
ChrisHarrington is offline
post #6 of 6 Old 02-14-2013, 10:33 PM
jautor's Avatar
Liked: 777
Originally Posted by ChrisHarrington View Post
Use lamp cord.
Lamp cord, while fine for speaker wire generally, is NOT rated for in-wall installation...
jautor is offline
