Need Urgent Advice for projector!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-18-2013, 01:13 AM - Thread Starter
HomeTheaterGuru's Avatar
I have a $4500 (US Dollars) max budget for a projector. Currently I am looking at the JVC X55 for $4200 or Epson 6020 UB for $3300. If any one has better advise, or to choose one among those two, it will be greatly appreciated.
First Home Theater Setup.
HomeTheaterGuru is offline
post #2 of 10 Old 01-18-2013, 06:45 AM
smuggymba's Avatar
Quoted: 113 Post(s)
Why did you rule out Panasonic PT AE8000; it seems to have great reviews.
smuggymba is offline
post #3 of 10 Old 01-18-2013, 08:06 AM - Thread Starter
What my plan is to have a 176" 2.35:1 screen and I just noticed that the epson does not have lens memory so I will not be able to switch between two modes (16:9/2:35:1). Also according to my installer, he said JVC is better that Panasonic. But I am also looking at that one too. The only reason I am leaning towards a JVC is because their numbers make more sense when you compare contrast ratios (500000:1, Vs. 50000:1) I double there is such thing as TRUE 500000:1. But Thanks for the suggestion I will look at that projector as well!
post #4 of 10 Old 01-18-2013, 09:00 AM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
That's a HUGE screen! I'm not sure any of those projectors (or anything in that price range) is going to give you acceptable results... I suggest you post / read a bunch of threads in the "Digital High-End Projector" forum before pulling any triggers.
jautor is offline
post #5 of 10 Old 01-18-2013, 11:29 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
When an installer says something like that, it often really means that his margins are better on the recommmended equipment. You need to do your own evaluation and make your own decision.
These contrast ratios are insane and unrealistic when it is all going to be overshadowed by screen choice, and ambient light in the room. This probably shouldn't be the killer criteria in making a decision. Now if the contrast ratio was 500:1...
I calculated that a 172" 2.35:1 screen is 68" high, or nearly 6' Do you have the ceiling height in your room to support that. Ideally, you want eyeballs about 1/3 of the way up. Figure your eyes in the first row are 4' off the ground, you would need about 2 ft from the floor to bottom of screen. That means a minimum of an 8' ceiling, and ideally at least 9'. You would also want to be sitting at least 12' and preferably closer to 15' back. Is your room large enough to support that?
Also second Jeff's comments (as usual)
jayn_j is offline
post #6 of 10 Old 01-18-2013, 03:33 PM - Thread Starter
Yes that is about exactly how big my room is with 8 ft ceiling. and 25ft long.
post #7 of 10 Old 01-18-2013, 03:34 PM - Thread Starter
The urgency is that I have placed an order foEpson 6020UB and if I need to cancel it, I need to do it very soon =)
post #8 of 10 Old 01-18-2013, 04:04 PM
jautor's Avatar
Liked: 832
I think you should be very concerned about using projectors in this price range for a screen of that size. What's your seating distance(s). 120" may be a better target...
jautor is offline
post #9 of 10 Old 01-21-2013, 08:15 AM
reedl's Avatar
Personally, I would not put a screen that big in a room with 8 foot ceilings, but that is me. I think that having that large a screen results in viewing fatigue where you need to actually move your head back and forth to view the screen. Having to move your eyes is one thing, but having to move your head results in being tired after watching a movie.
I liken it to sitting in the front row of a movie theater. I guess some people like it, but myself, I prefer to be able to see the whole picture in my peripheral vision.
Plus if you have two rows or more, you are going to have to raise the back rows up to get over the first row people in order to actually see the lower part of the screen.
Check out my theater! My Theater
Here is the Arcade: The Arcade
reedl is offline
post #10 of 10 Old 01-28-2013, 06:01 PM - Thread Starter
Hey everybody thanks for you suggestions! I have moved this forum and here is the link!
http://www.avsforum.com/t/1454985/first-projector-home-theater-setup-suggestions
