Living Room compact 2/3 speaker setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-21-2013, 09:47 PM - Thread Starter
sjavs's Avatar
Moving to a single family home with plans for a basement entertainment room. But for now, want something effective for the living room that is small - no towers. Since the TV is going to be in a corner, not sure how much space would be left even for bookshelves. I was thinking either two good fronts or fronts + a center. Primarily for good dialogue audio since with an infant at home, not going to watch action / loud audio movies.
Any suggestions? Budget is pretty flexible.
Sent from my Nexus 10 using Tapatalk 2
sjavs is offline
post #2 of 5 Old 01-22-2013, 09:57 AM
bepperb's Avatar
First suggestion is to train your child to sleep through anything and get back into those action movies.
My advice would be to find a way to fit some bookshelf speakers into the mix (maybe look for front ported ones that you can get pretty snug to the wall) and you can always add a center later if you think you need it, and even surrounds if you move downstairs. There aren't many bookshelf speakers that don't have a matching center anymore.
Finishing up my basement with 5.1 but I'll be keeping a set of Paradigm bookshelfs upstairs for movies but also for ambient music. Music sounds horrible on HTIB (or even worse TV) sized speakers.
bepperb is offline
post #3 of 5 Old 01-22-2013, 02:38 PM - Thread Starter
sjavs's Avatar
I should've provided some context here. I currently have a good 7.1 setup in the apartment with two floor standing fronts, a center, 5" bookshelves for surround, 12" SW and a Yamaha receiver. All that with enhancements will go to the basement - probably add a better receiver or dedicated amp for fronts and an extra sub.
For the LR, the space is controlled by aesthetics. I have to do best in the provided space. The LCD TV is going to be a corner wall mount and with a small component stand. This is the chosen component stand:
http://www.standsandmounts.com/bushvisionscollectionflatpanelcornertvstand-vs97227-03.aspx
I am thinking, I can fit two sound-bar or center type speakers (but not powered) vertically on sides of the stand, place a 6-8" SW in the bottom shelf and if need be add a center on top of the stand (same as the fronts). Was looking at Yamaha NS-C310 to be used as fronts. These will be driven by a Yamaha RX-671.
Thoughts?
sjavs is offline
post #4 of 5 Old 01-23-2013, 11:30 AM
bepperb's Avatar
In that stand the speakers would be so close I would just get a pair and run in stereo, I assume the Yamaha will do a "phantom" center channel or downmix everything to stereo.
2.5" woofers would make me buy the stand first and hope I could fit something larger in there after taking some measurements. Even with a sub I'd be worried about a lull in the low male voice range (to say nothing of how hard those would be working to fill a room with music).
bepperb is offline
post #5 of 5 Old 01-28-2013, 12:25 PM - Thread Starter
sjavs's Avatar
For front speaker pair, I am looking at HSU HB-1 Mk2 now. Looks like it is hard to go wrong with the HB-1s for the money.
For the receiver/amp, I am undecided. I could use my Yamaha RX-671 to drive two fronts, a center and a sub and give good support to the fronts by bi-amping. On the other hand, I could go with a stereo receiver since I don't need all the other features of the RX-671 especially all the HDMI switching since the TV can handle that. The HK3390/3490 seem to have good reviews for a stereo amp.
http://www.amazon.com/Harman-Kardon-HK-3490-Receiver/dp/B00198F89A/ref=sr_1_7?s=aht&ie=UTF8&qid=1359400993&sr=1-7&keywords=stereo+amplifier
But I forgo the center with a stereo amp.
Choices, choices! :-)
sjavs is offline
