Help with my projector home theater build please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-22-2013, 06:53 PM - Thread Starter
djrobd732's Avatar
I'm having an issue with my projector setup I attached a pic if anyone can help I'd appreciate. This is my first build so I'm by far a professional. I purchased the optoma th1020. I'm building my screen DIY projector screen. My room is 15 1/2 x 15 1/2 . The ceiling height is 7' 2" . I've purchased a ceiling mount . The seating is going to be all the way to the back wall. Well the screen I really want is 104" like the pic I attached I outlined with blue tape.i really wanted to mount the center speaker underneath the screen in the wall but the gas line is in the way and possibly the entertainment center. I've done the projector screen calculator and it say for that size screen the projector has to be 12' 5" away wich is no problem but I have to drop the screen down 8" inches down from center of lense. That would bring it to low maybe I'm not understanding that correctly. But I guess my biggest problem is really mounting the center speaker under the screen in the wall. If anyone can help I'd appreciate it!
djrobd732 is offline
post #2 of 5 Old 01-22-2013, 06:55 PM - Thread Starter
djrobd732's Avatar
I'd like to add a panoramic shot maybe this helps describe my issue.
post #3 of 5 Old 01-22-2013, 07:17 PM
jautor's Avatar
Quoted: 1219 Post(s)
Liked: 782
Hire a plumber to relocate the gas line... Looks like there's plenty of room to simply move it higher in the wall.
Assuming that's an exterior / load-bearing wall, if you're going to cut the stud away to make room for the speaker, you'll need to install a header in that cut out space.
jautor is online now
post #4 of 5 Old 01-22-2013, 07:36 PM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
Ok,
First are you dead set on inwalls and if so, why? If you would have "regular" speakers that would solve your "mounting" problem.
Not sure about the projector you have and it's mounting requirements, but I can assure you that you don't want the top frame right against the ceiling unless you can't help it. The reflections from the screen onto the wall could be bothersome.
You could use a smaller/shorter media cabinet or move it over to either side. Doing so would give you the option of moving the speaker down. If you are doing inwalls then you could take the opportunity to mount the speaker below the gas line and frame in a box for it as it will most likely be horizontal vs. vertical like the sides would be.
RTROSE
RTROSE is offline
post #5 of 5 Old 01-22-2013, 09:03 PM
jautor's Avatar
Liked: 782
RTROSE brings up very good points (my neck hurt from trying to see your picture biggrin.gif ). If you're going to have a media console anyway, a center channel can go on top of it easier than in-wall. L/R on stands would give you a lot more options, too. If you stick with in-walls, those L/R positions look too high - they should be closer to ear-height and matching the center (otherwise you'll get odd-sounding pans across the front soundstage).
