Paint exposed ceiling black? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-24-2013, 05:40 PM - Thread Starter
canadian85's Avatar
I'm looking to part finish my basement for bar, games area and spot to watch movies (not really a theater though). On a budget and want to do something different. Thinking of painting the exposed ceiling black with a wagner sprayer. The furnace and water heater have open flame. Should I be closing off the furnace area before I paint ceiling? I can open the windows but they're small so there won't be alot of air movement.
canadian85 is offline
post #2 of 9 Old 01-24-2013, 07:41 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Really? This is a question???
From THE FIRST PAGE of the manual:
b) WARNING - To reduce the risk of fire or explosion:
1. Do not spray flammable or combustible materials near an open flame, pilot lights or sources of ignition such as hot objects,
cigarettes, motors, electrical equipment and electrical appliances.
jautor is offline
post #3 of 9 Old 01-24-2013, 08:35 PM - Thread Starter
canadian85's Avatar
If you're talking about the manual for the sprayer, I don't have one. And I've never used a paint sprayer before. Just an idea at this point. Should I just turn them off while i'm spraying and for a few hours after? Or what do people usually do?
post #4 of 9 Old 01-24-2013, 10:11 PM
jautor's Avatar
Liked: 777
http://lmgtfy.com/?q=wagner+power+painter+manual&l=1
I would certainly turn them off during the painting, open the windows, put a box fan in one window to circulate air, and leave it there for a while after you're done. Don't think you need to leave them off for several hours, but if it were me, I'd leave everything turned off as long as practical, though... Keep the air circulating to get rid of any paint particles in the air.
jautor is offline
post #5 of 9 Old 01-25-2013, 06:39 AM - Thread Starter
canadian85's Avatar
Thanks, I'll look into it more.
Geeze, flamed on my first post! I thought I was having sense thinking about that before anything else..
I tried a search but couldn't find much about this. Has anyone done this and had problems with peeling on any surfaces? The ductwork can get pretty warm, would this create problems with the paint?
I'm assuming I should use a different kind of primer since i'm painting the ductwork wood and wires. Any recommendations or should I just go by what the paint store says to use?
post #6 of 9 Old 01-25-2013, 07:19 AM
jautor's Avatar
Liked: 777
Well, you are asking questions completely unrelated to home theater...
I tried a search but couldn't find much about this. Has anyone done this and had problems with peeling on any surfaces? The ductwork can get pretty warm, would this create problems with the paint? I'm assuming I should use a different kind of primer since i'm painting the ductwork wood and wires. Any recommendations or should I just go by what the paint store says to use?
Definitely talk to the paint guys. I'd imagine you might have trouble getting normal latex to adhere well to metal ductwork without the right primer. I'd also have a conversation with the paint guys about the type of sprayer to use - I'll bet they'll recommend renting a "real" one.
And you are obligated to post pictures of the results! Good luck,
Jeff
jautor is offline
post #7 of 9 Old 01-25-2013, 08:26 AM - Thread Starter
canadian85's Avatar
I've been reading these forums for a while, just to get ideas for my basement. There are alot of awesome basement and bar builds (and knowledgeable people) on these forums so couldn't think of better place to post.
While I know this site is meant for home theaters, I was hoping to get some advise while I do my basement. And when I start I have pics.
post #8 of 9 Old 01-25-2013, 08:48 AM
jautor's Avatar
Liked: 777
Oh, don't blame you there... The forum has a wealth of knowledge on all construction-related topics. I just had to laugh at you. biggrin.gif I mean, you knew enough to call it an "open flame", which is exactly the terminology the safety warnings always use.
If you post a sketch with dimensions (draw it on paper and take a photo if that's easier), you'll get all kinds of advice on layout.
Jeff
jautor is offline
post #9 of 9 Old 01-25-2013, 08:59 AM - Thread Starter
canadian85's Avatar
Guess that's what happens when I ask a stupid question..
I've got a plan drawn up on cad, I'll post when I get a chance.
