Can light depth - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-26-2013, 07:27 AM - Thread Starter
JReuter21's Avatar
Quoted: 61 Post(s)
I'm building soffit around my ductwork that will be directly above my bar top. I want to put recessed lighting in the soffit but am not sure how far I need to build it down to have enough room to fit the cans between the sheet rock and the ductwork. Anyone have any idea?
JReuter21 is offline
post #2 of 3 Old 01-26-2013, 07:54 AM
airscapes's Avatar
Quoted: 389 Post(s)
Liked: 307
There are about a billion kinds of recessed lights. You need to figure out what you want to buy before you plan your soffit. They range form a couple of inches to 8" or more. More head room is better but smaller is not always the least expensive.
Just do a google "Recessed lighting depth" or "Recessed lighting types", then start reading lots of info and things you need to know before you start building.
These are just the first couple of hits
http://www.delmarfans.com/recessed_lighting_guide.cfm
http://lighting.lucepedia.com/lighting/Shallow%20Recessed%20Lighting
http://www.electriciantalk.com/f2/shortest-recessed-light-19481/
http://www.home-style-choices.com/recessed-lighting.html
http://www.lightingshowplace.com/recessed-lighting-basics/c80849
http://community.homedepot.com/t5/Install-Replace/How-to-Choose-the-Right-Recessed-Lighting/td-p/44195
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 3 Old 01-27-2013, 01:25 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
There are also LED 'Can' lights that are virtually surface mounted.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
