Anyone used a surge protector/noise filter receptacle such as leviton 5280-W? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-28-2013, 05:09 PM - Thread Starter
metropole's Avatar
Quoted: 47 Post(s)
This might be a bit overkill as I am already using a quality APC UPS for my gear.
However, I thought it still makes sense to add a bit extra protection. Further, my dimmer can cause my APC to make some noise. I tested several dimmers and the one I am using caused the least noise.
Has anyone come across the surge protector/noise filter combos?
I found the Leviton 5280. Are there better ones?
metropole is offline
post #2 of 3 Old 01-28-2013, 07:55 PM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
I installed the Leviton 5280 surge protected outlet last week into a LV enclosure, with my modem, router, and a switch running to it. I extended the power from that outlet to a nearby Midlite male power inlet, and then to my rack with a power cord. I'm using a Cyber power battery backup UPS in the rack. I only used the 5280 because I had it; it was originally planned as the only SPD for the LAN equipment. I wouldn't normally use 2 SPDs in series.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 3 Old 01-29-2013, 10:50 AM - Thread Starter
metropole's Avatar
Quoted: 47 Post(s)
This model claims to filter -30dB starting at 500kHz. I wonder if this would filter my dimmer generated noise?
Related, does this filter our power lien communication such as X10, Insteon?
