What color to paint baseboard trim - AVS Forum | Home Theater Discussions And Reviews
Old 01-31-2013, 03:39 PM - Thread Starter
Adam34996's Avatar
So I painted my white trim red to match the walls but I am not sure I like it. Should I go back white? Or maybe black? Please help
Adam34996 is offline
Old 01-31-2013, 10:44 PM
iamjason's Avatar
Quoted: 31 Post(s)
my room has the same colors - i would go black base boards - on the red walls it is an accent color and on the screen wall it blends in and is not a visual distraction.
iamjason is offline
Old 01-31-2013, 10:49 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
+1 for black.
Then get some black outlet / keystone plates to replace those white ones on the screen wall, too.
jautor is offline
Old 02-01-2013, 07:46 AM
Bucsroom's Avatar
black
Doug
Terra Ceia, FL
Bucsroom is offline
Old 02-02-2013, 09:04 PM
rmajor55's Avatar
Robin Major
I never know what to put here.<---- Soon to be build thread.
rmajor55 is offline
Old 02-05-2013, 03:29 PM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
Black, the red is drawing your eye away from the screen and competing for attention. It should just blend into the screen wall.
Play like a Raven
design1stcode2nd is offline
Old 02-07-2013, 05:08 PM
hltr's Avatar
Liked: 25
Black, unless for some reason you want to draw the eye there ;-)
____________________
Brian's Bar Build
hltr is offline
