Home Theater Computer (Windows 7) - HDMI Receiver connection PROBLEMS......... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-05-2013, 06:07 AM - Thread Starter
vision-master's Avatar
Liked: 24
Ok, my Windows 7 box dosen't like the HDMI imput on the back of the reciever. When connecting Computer (HDMI) TO Receiver TO Plasma TV, Windows desktop is too large to fit monitor, also the sound card doesn't work?
Adjusting 'Screen Resolution' dosen't do the trick?
So,,,,,, as of now, Windows is connected directly to an HDMI imput on the Plasma TV with audio out RCA jacks to 'tape monitor'.
vision-master is offline
post #2 of 3 Old 02-07-2013, 01:47 PM
fefzero's Avatar
As for the screen resolution, you may have a setting on your TV (if yours is like mine) that prevents it from showing the full image. Try to check all your TV's settings and see if there's one you can use to shrink the size of the picture down.
fefzero is offline
post #3 of 3 Old 02-07-2013, 02:26 PM - Thread Starter
Liked: 24
Ok, thanks.
