Power Strip with Unswitched Outlets? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-05-2013, 12:55 PM - Thread Starter
Noobio2's Avatar
Why am I having so much trouble finding a basic power strip with an unswitched outlet or two? My HT is pretty low budget, and I am not looking for anything too complicated and fancy. There are plenty of $30 to $50 devices that would meet my needs perfectly, but almost none of them have an unswitched outlet for the DVR. Why is this such a rare feature? Does anyone have any recommendations?
The only line I've found so far are these from Belkin, but I don't want or need a remote, and the reviews suggest that the remotes are prone to failure anyway.
Any other ideas (in my price range) greatly appreciated. Thanks!
Noobio
Noobio2 is offline
post #2 of 2 Old 02-05-2013, 01:02 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Because you're trying to do something that a regular, cheap power strip isn't meant for...
Just run your DVR to the wall outlet, or better yet, to a UPS, and leave all the switched stuff on the power strip.
Or since you were already onto the Belkin products - they have a $30 one that does exactly what you need:
http://www.amazon.com/Belkin-Conserve-Socket-Energy-Saving/dp/B003P2UMQ2/ref=pd_sim_e_1
"2 Not-Controlled outlets for continuous power to cable/satellite boxes and DVRs"
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
