Run wires behind baseboard, but 1) With wire channel, or 2) without wire channel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-15-2013, 04:15 PM - Thread Starter
lnong's Avatar
Quoted: 57 Post(s)
Liked: 24
So I'm trying to decide to run wires in the drywall using a wire channel, like this:
http://on.aol.com/video/how-to-hide-wires-with-a-baseboard-wire-track-172963162
Or, run them in the wall without using a wire channel, like this:
http://www.diynetwork.com/how-to/how-to-hide-wiring-behind-baseboard-or-installing-a-raceway/index.html
To me, doing it without a channel seems to be cleaner and easier. Another thing is that using a channel, it seems like you need to be sure that the thickness of the channel (with the cover on) has to be least than or equal to the thickness of the drywall. If not, when you put the baseboard back on over the channel, there's gonna be a little gap b/t the baseboard and the wall.
Plus not buying channels will save $$.
Am I missing something here? What do you guys think is the better way to go??
TV: Samsung 85" UN85HU8550 (TD01) with SEK-3500
AVR: Marantz SR7010
Speakers: Dynaudio Audience
lnong is offline
post #2 of 10 Old 02-15-2013, 04:38 PM
Colm's Avatar
Liked: 94
If your baseboard is thick and wide enough, just route a groove of appropriate size in the baseboard. Remember not to nail where the groove is.
Colm is offline
post #3 of 10 Old 02-18-2013, 11:12 PM
eyekode's Avatar
Quoted: 21 Post(s)
I am not sure I understand the wire track either. To make it look good you would have to caulk and paint the baseboard anyway right ? So getting back in there will not be easy.
When I ran my surrounds I removed the baseboard and cut ~ 1" off the bottom of the drywall and ran my cables in the space where the drywall was removed. Then I just put the baseboard back up and caulked/painted (including the wall) etc. I managed to run 4 channels of 14 ga and an RCA cable in that space.
Note I am not an expert by any means, just sharing my experience.
Salem
eyekode is offline
post #4 of 10 Old 02-21-2013, 09:34 AM
ctviggen's Avatar
Quoted: 115 Post(s)
Liked: 32
Salem
In a 1 inch by 0.5 inch (depth of drywall) space, you ran 4 channels of 14 gauge wire and an RCA cable? That seems like a lot in such a small space.
Bob
ctviggen is offline
post #5 of 10 Old 02-21-2013, 10:55 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
This is a good resource for retrofitting cables.
http://www.hometheatershack.com/forums/home-theater-design-construction/6038-how-wall-wiring-your-home-theater.html#post47983
When I run cables behind a baseboard, I cut out some of the drywall, and drill holes in the studs.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 10 Old 02-21-2013, 10:59 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
If the drilled holes are near the front of the studs, use nail plates to protect the cables.
Neurorad is offline
post #7 of 10 Old 02-21-2013, 11:45 AM - Thread Starter
lnong's Avatar
Quoted: 57 Post(s)
Liked: 24
Yeah, I had already read and bookmarked that article. Really good details and great advice in there.
Anyway, for those of you who cut out the bottom portion of the drywall and ran the wires in that space (instead of threading them through the drilled studs), how did you guys reattached the baseboard trim over that cutout? If I'm visioning it correctly, you can only nail or glue the top part of the baseboard trim to the bottom edge of the drywall, right? Because, there is no drywall left at the bottom to nail/glue the bottom portion of the baseboard trim to....
AVR: Marantz SR7010
lnong is offline
post #8 of 10 Old 02-21-2013, 03:09 PM
eyekode's Avatar
Quoted: 21 Post(s)
I simply nailed the trim back avoiding the lower edge of the trim. I see no bad effects of doing it this way. You cannot do this with high voltage of course.
Salem
eyekode is offline
post #9 of 10 Old 02-22-2013, 07:12 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
If you don't want to drill the studs, another option is to cut a channel in the drywall a couple inches from the bottom - 2 cuts, instead of one at the bottom.
It's a forgiving process, with everything covered by the baseboard. Hard to screw it up. The only difficulty, in my experience, is caulking the edge and painting nail holes.
For posterity, be careful of toenails in the bottom of the vertical studs, when drilling. They will dull your bit, and could give your wrist a strong yank if they stop the bit.
Neurorad is offline
post #10 of 10 Old 02-22-2013, 07:14 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I would avoid gluing the baseboard. Hard to get back in easily, for future cables, and replacing damaged cables.
Neurorad is offline
