Low voltage conduit rough-in question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-08-2013, 04:16 PM - Thread Starter
Tehrab's Avatar
I am about 5 weeks out from doing the low voltage rough-in in my new house and had some questions for the gang here at AVS:
I'm going to be running 1" carlon orange conduit from all my LV boxes to a structured wiring panel. My wiring panel will chase to the attic where necessary and I was wondering what the best practice/code compliant method was for reducing my 1" conduit runs down to the chase. Will I need a junction box somewhere in the attic? Can I just leave the 1" conduits open ended somewhere near the chase(s)?
Tehrab is offline
post #2 of 8 Old 03-08-2013, 04:29 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
The conduit can end in the attic without connecting to anything.
I suggest you install cables during construction, outside of the conduit, and also install empty conduit. The conduit is for future cables you forgot or aren't available yet, e.g. HDMI 2.0.
If you don't like leaving the conduit open to critters/bugs, you can use Duct Seal putty.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 8 Old 03-08-2013, 04:30 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
FYI, 1" is kind of small for HDMI connectors.
Neurorad is offline
post #4 of 8 Old 03-08-2013, 05:18 PM - Thread Starter
Tehrab's Avatar
Awesome, thanks for that info. Also, my HDMI runs are a separate concern altogether.
Tehrab is offline
post #5 of 8 Old 03-09-2013, 08:23 AM
ctviggen's Avatar
Quoted: 116 Post(s)
Liked: 32
1 inch is way too small, especially to put cable through.
Bob
ctviggen is offline
post #6 of 8 Old 03-11-2013, 10:45 PM
mn_hokie's Avatar
Liked: 27
2 inch minimum, with 3-4 preferred.
mn_hokie is offline
post #7 of 8 Old 03-16-2013, 11:47 AM - Thread Starter
Tehrab's Avatar
My HDMI runs have dedicated framing. Framing which will also house my conduit.
Tehrab is offline
post #8 of 8 Old 03-16-2013, 12:19 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Your will have a tough time putting new HDMI cables through that conduit, in 10 years.
But, by then, we may just serve content from our home networks, so who knows if you'll ever need the conduit. If you are installing the conduit so you can run a new HDMI cable some day, use 1.5" at a minimum.
Neurorad is offline
