Possible build in a finished basement room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-14-2013, 01:45 PM - Thread Starter
vivithemage's Avatar
Quoted: 26 Post(s)
I am moving into a house with a finished basement...a few electrical outlets is about all there is and a duct over the top.
This is a picture of it:
green = windows
red = walls
gray = understairs room ... possible placement for gear
pink = projecter screen
purple = projecter location
yellow = doors
maroon = 2 x 3 foot droop for the air ducts
Does this make sense, the room is only about 13 feet wide... I will put a nice L shaped couch under the projector itself, unless it'll be too loud with the projector right above us.
Do you think this will work well? Or can anyone think of a better configuration?
vivithemage is offline
post #2 of 10 Old 03-16-2013, 10:11 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
So the room is 13ft wide (across the walls with the windows). How long is the room?
Soundwise, its generally better to have the LCRs on the narrow wall, so that you are not sitting up against the opposite wall.
I think I would place the screen over one of the windows and mount the projector to the duct soffit.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 10 Old 03-17-2013, 12:16 PM - Thread Starter
Quoted: 26 Post(s)
Not a bad idea, but I would hate to lose the natural light throughout the day, when we aren't using that half of the room for movie watching.
I would also have an issue with couch placement I think ... as the doorway to the right would be blocked almost...I would also have to run power/cables up to that area which would kind of suck. The proposed method is decent, because the projector will be right along the wall with power/hdmi already to my receiver.
Do you think the w1070 will throw 120" + or should I get the short throw version? w1080st to get 120"-140" ?
Or also considering the new and un reviewed Acer H6510BD...
I was thinking of getting book shelf speakers for the 2 fronts LR and a decent center + sub .. and mounting to small bookshelfs in the corners fore the 5.1 effect.
post #4 of 10 Old 03-17-2013, 08:38 PM - Thread Starter
Quoted: 26 Post(s)
any idears on that?
post #5 of 10 Old 03-18-2013, 09:09 AM - Thread Starter
Quoted: 26 Post(s)
Do you guys think the W1070 can throw 120" + at 11 feet ceiling mounted? or is that asking too much and I should go with the w1080st ?
post #6 of 10 Old 03-18-2013, 09:55 AM
gitSehT's Avatar
Powered Retractable screen over the window?
gitSehT is offline
post #7 of 10 Old 03-18-2013, 10:49 AM
Bacon13's Avatar
Liked: 39
Take a look at the projector calculator at the Benq site. That will answer your questions.
Bacon13 is offline
post #8 of 10 Old 03-18-2013, 11:10 AM - Thread Starter
Quoted: 26 Post(s)
Yeah, I was afraid it might not be able to throw it at 11 feet ... so I am now thinking of the W1080ST or the W710ST...those can definitely do it. Save $500 and go 720p too, if I did the 710ST ... I might just do it, since this is my first projector setup.
post #9 of 10 Old 03-18-2013, 12:56 PM
Bacon13's Avatar
Liked: 39
I guess I don't understand what you are asking. Are you saying you need to mount it right at 11' or that is the furthest from the screen you can mount it?
According to the Benq calculator for a 120" screen you are limited to the following distances:
W710ST 6'3" to 6'11"
W1080ST 6'0" to 7'3"
W1070 10'1" to 13'0"
So... either way the W1070 would work. If you can mount it closer than 11' to the screen then the W710ST and W1080ST would also work.
Bacon13 is offline
post #10 of 10 Old 03-19-2013, 11:07 AM - Thread Starter
Quoted: 26 Post(s)
