Recommendations for TV wall mount? - Page 2 - AVS | Home Theater Discussions And Reviews
post #31 of 54 Old 11-13-2013, 07:46 AM
labboypro's Avatar
Liked: 24
I need something that articulates out (like the Cheetah) because my TV flush-mounts into a false wall... so there's no way to get enough fingers around it to hang it using these fixed mounts. I only need 4-6" of front-to-back articulation, bit it's required. Hopefully those mounts work out for your installations. I'm going to keep looking.
labboypro is offline
post #32 of 54 Old 11-13-2013, 09:37 AM
dalearyous's Avatar
if you find one let me know. amazon shipped me the wrong articulating mount the first time and i might not return it now. its about double or triple the hefty-ness of the cheetah but the wall plate was a bit too small to reach the studs. but at this point it might be worth keeping the sturdy mount and cutting a hole on the other side of the wall and add some more framing so the mount works. again still pondering. ill take a picture of it and post it to see if someone can identify it. its a beast.
dalearyous is offline
post #33 of 54 Old 11-15-2013, 07:03 AM
dalearyous's Avatar
Originally Posted by dalearyous View Post
i ordered this one and will be giving it a try:
http://www.amazon.com/gp/product/B004UWXW0Y/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
so this mount worked great! comes with great hardware and screws. no issues at all. very solid and the tilting brackets are very sturdy. i will say that if you want a super flush mount this might not work as it does make the TV hang off the wall. i don't care in my situation because of my old plasma has a very thick base so in my case it worked perfectly.
post #34 of 54 Old 12-23-2013, 04:09 PM
jjk454ss's Avatar
Any new suggestions? I am looking for an articulating mount that sits very flush when pushed against the wall. I'd like a good quality one without spending too much(of course). I hear good about the monoprice, then I hear bad. Same got the Cheetah, good and bad. It needs yo hold a 55vt50, so nothing like the 65" TVs others are mounting.
jjk454ss is offline
post #35 of 54 Old 01-05-2014, 04:17 PM
jjk454ss's Avatar
I haven't decided on a mount yet, I don't want to get one only to find it doesn't work well. Any suggestions?
jjk454ss is offline
post #36 of 54 Old 03-14-2014, 07:21 AM
shorty123's Avatar
Instead of starting a new thread, I thought it would be better to add to this thread. I am looking for a wall mount which would give me some access to the back of the tv for a 65'' or 75'' led tv. If a tilt mount would give us enough access, that would be fine. I don't know if I need to go with an articulating mount. I assume that a fixed position wall mount would not work for me. I was wondering if there are any other good mounts similar to Sanus VLT5.
shorty123 is offline
post #37 of 54 Old 03-14-2014, 09:21 AM
BasementHT5's Avatar
Quoted: 16 Post(s)
I just ordered this one from monoprice for my 70" TV:  http://www.monoprice.com/Product?c_id=108&cp_id=10828&cs_id=1082801&p_id=6663&seq=1&format=2
they also have a full swivel here:  http://www.monoprice.com/Product?c_id=108&cp_id=10828&cs_id=1082806&p_id=6517&seq=1&format=2
I have a monoprice mount for my 52" TV in my family room that I've had for 5+ years that worked great.
Gear: Visio 70" M701d-A3R LED TV | Onkyo TX-SR606 | Sony BDPS5100 (blu ray) | SONY PS3 | Polk 265-RT (L/R) | Polk 255C-RT (C) | Polk RC65i (L/R rear Surround) | Polk RC80i (L/R Surround) | SVS PB-2000 (Subwoofer) | Harmony Smart Control (Remote)
BasementHT5 is offline
post #38 of 54 Old 03-14-2014, 02:27 PM
shorty123's Avatar
Those are lot less expensive than the Sanus tv mounts. Thanks for the info.
post #39 of 54 Old 03-14-2014, 03:00 PM
NickTheGreat's Avatar
Quoted: 191 Post(s)
Liked: 128
I have the baby brother of that articulating Monoprice one. Great mount! smile.gif
NickTheGreat is offline
post #40 of 54 Old 05-29-2014, 03:24 PM
labboypro's Avatar
Liked: 24
Originally Posted by JBWIII View Post
...even the fancy brands have quality control issues. Maybe return the Cheetah for a replacement, or just call them and demand a replacement part.
Because I'm a glutton for punishment, I'm going to try again with another one of these mounts. I sold my last home with mancave intact, which means I get to build a new one from scratch in the new house. This time I'll be going with a 70" that weighs about 95#. I'm hoping that the lighter weight, smaller size, and hopefully getting a "better production run" from Cheetah will mean this mount works better than the last one.
I have long been very happy with this Monoprice unit for my bedroom 40", but was worried that their 60" top spec would be an issue for the larger unit (??)
post #41 of 54 Old 06-06-2014, 09:11 AM
labboypro's Avatar
Liked: 24
Holy moley... what was I thinking?
This new IDENTICAL PART NUMBER AS THE LAST ONE unit is completely different. It came as a damn Heathkit that I had to assemble. Both the wall plate and TV plate are now cut in half, then tied back together with nuts and bolts and self-threading screws (5 nut/bolt/lock washer combos for the wall plate... and metric equivalent of about 3/16" shaft! ... and 4 carriage bolts with nylock nuts on the TV plate... metric equivalent of about 1/4"). Then, I had to assemble 3/6 of the articulating legs, including bushings, etc. It appears the SOLE benefit to breaking this thing down into a LEGO set and halving the mounting plates is to make the box smaller. And the trade-off is that what used to be solid plates for wall and TV mounts are now the same amount of steel with a giant seam down the middle, stitched back together with a little bracket and some flimsy bolts... so for the TV side, this puts the ENTIRE downward load directly on the heads of 3 scrawny bolts instead of a solid steel plate... the solid steel-ness is all wasted. In all, there were 27 pieces/sub-assemblies I had to piece together just to get to where I was the instant I opened the box on the previous one of these I purchased last year. I'm done with Cheetah. You should be too.
/2 cents
post #42 of 54 Old 06-07-2014, 10:03 AM
uberish's Avatar
After delaying and delaying I've decided to wall mount. Mostly cause I need more space on the console to place other goodies.
Normally I'd jump on the amazon or monoprice offerings but I've noticed a lot of the previously well reviewed models have less than stellar RECENT review with a lot of complaints of design changes and a decline in quality.
Can anyone recommend based on a recent purchase?
I have no issues buying a non brand name "budget" mount or whatever. But with plasmapheresis being discontinued I'd be very upset if my panny tumbled due to poor craftsmanship.
uberish is offline
post #43 of 54 Old 06-07-2014, 12:41 PM
labboypro's Avatar
Liked: 24
I have used this one from Monoprice on two different installs, and found it to be nothing less than superb... heavy steel construction, smooth articulation arms, and reasonably easy to tilt down or up as needed. It is described as good for 37", and my 2 installs were both 40's, which worked fine. I would have used it on my current 70" install (see a couple of posts up), but I needed 400x400 VESA. Purchases were approx 2 years ago, so no idea if they've crapped out on this model or not.
post #44 of 54 Old 06-08-2014, 09:20 AM
JBWIII's Avatar
Liked: 42
The good news is that most of the problems that people have been reporting here are evident from the moment you take the mount out of the box. For example when I helped my friend with his Sanus VLT15, we could tell instantly that one of the clutches was slipping and that the TV could unexpectedly tilt downward.
My advice would be to order whatever mount looks like it will meet your needs, unpack and install it, and then make your own assessment as to the stability of the particular mount you received. If you feel uneasy about it, take it down. If not, it will probably be fine.
labboypro likes this.
JBWIII is offline
post #45 of 54 Old 06-08-2014, 09:32 AM
uberish's Avatar
True. I'm sure it's fairly easy to tell when something isn't solid even before you install. Referencing a model where they turned the one piece solid wall bracket into two pieces with a bolted seam to save on packaging. It's more like I didn't want to deal with returns and the delays involved with that kind of situation. I've new scouring the reviews and found a couple that still have positive reviews. Need to make a decision soon. My tv room looks like a bomb went off at this point.
uberish is offline
post #46 of 54 Old 06-08-2014, 02:27 PM
labboypro's Avatar
Liked: 24
I just ordered one of these for a new install... will post when I get it in my hands as to whether it is still as good as the previous ones I bought.
post #47 of 54 Old 06-08-2014, 02:54 PM
uberish's Avatar
I'm considering this: http://www.amazon.com/gp/aw/d/B004C4SC5U/ref=mp_s_a_1_12?qid=1402260206&sr=8-12&pi=AC_SX110_SY165_QL70
Or the sanus: http://www.amazon.com/gp/aw/d/B004FPYLKG?pc_redir=1402150823&robot_redir=1
If I had to pay for shipping from monoprice I'd get the sanus. But both being prime eligible the mono is half the price.
Only knock in the monoprice one seems to be some gripes with the tilting mechanism. One saying its too hard to get to another saying it flops around. Those may be user related errors from what I've seen.
Haven't had any issues with monoprice stuff yet so I'll prob give them a shot. Anyone on here use that specific one by any chance?
uberish is offline
post #48 of 54 Old 10-28-2014, 11:28 PM
johnny7175's Avatar
Sorry to drudge up an old thread but I'm looking for a wall mount that will extend over 36" for a new Samsung 51" TV that weighs 46lbs. I'm having a hard time finding a tilt/swivel mount that extends that far so hopefully someone can point me in the right direction.
johnny7175 is offline
post #49 of 54 Old 11-11-2014, 05:26 PM
Partyslammer's Avatar
Quoted: 14 Post(s)
Liked: 42
I would suggest the Peerless SA752PU articulating wall mount. It doesn't extend out quite as far as you require, but I have a 60 lbs+ 55" Samsung Plasma on mine and I can extend it out from the wall and turn it a full 90 degrees with a couple inches to spare from the wall to the edge of the tv. I bought and installed mine alone in less than an hour for the bedroom almost 2 years ago and have zero complaints. Extremely stable, very elegant looking and one of the few mid size fully articulating wall mounts that screws into a single vertical wood stud via 4 mounting screws. It runs under $200 on Amazon and if you have Prime the shipping is free making it a great deal.
Partyslammer is offline
post #50 of 54 Old 12-09-2014, 09:19 PM
RobD25's Avatar
any opinions on a single wall stud vs dbl wall stud brackets ?
Rob
UN48H6350
EPSON S-1, yeah, I collect antiques.. soon, soon, my dear...
had a Denon HT receiver (just crapped out)
RobD25 is offline
post #51 of 54 Old 12-10-2014, 06:50 AM
airscapes's Avatar
Quoted: 144 Post(s)
Liked: 148
I guess it depends on what the construction is like.. put a single stud chief 30" articulating mount in my living room and could do pullups on it till the end of time.
However there are wooden studs and 3/4" rock lath walls in my house. One thing to note if you have this or similar type of construction, when tightening the lag bolts it is very likely you will end up with a few nail pops near the mount as the wall board is cranked in tight. Oh and with a single stud mount, Mark your top hole, drill the pilot and put the lag bolt in till the mount is snug. Now use your level to get it perfectly plumb,snug up the top bolt so the unit will not move and drill the pilot hole for the bottom and install the bolt.
This prevents a very slight out of plumb that will be magnified at the far end of the mount.
Some pictures with comments under them once you click the thumbnail Livingroom update
And yes, I hate those long plastic extensions on the mount.. would have looks a lot cleaner had the made small covers for the wall mount end.
Doug
Planar PD8150 paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #52 of 54 Old Yesterday, 02:00 PM
michaelwalsh's Avatar
I never know if it's better to start a new thread of dig up an old one, but here goes...
I bought the Cheetah APDAM3B articulated mount for my 42" LG (weighs just 30lbs) and am having trouble with the arms sagging that appears to translate into tilt at the TV's screen. You won't see it much in the picture attached because I cancelled most of it out using plastic spacers supplied with the mount (ostensibly for TVs with rounded backs) to kick out the bottom of the TV by 30mm, but before I did it was about 6 degrees of tilt even with the actual tilt adjustment in the VESA mount brackets set to zero. Even with the 30mm worth of spacers installed at the bottom of the brackets it still has about 2 degrees of tilt (which just happens to be the amount of tilt at the end of the mounting bracket without a TV hanging off of it). It's really been quite a frustration and in my mind I can already see a diminishing return from adding more spacers.
I have a feeling that it may be a combination of arm bolts that aren't tight enough and the plastic spacers at the joints, but I haven't taken my TV down to fool with it again yet. I like the mount and, as you can see, my set is centered beautifully in the recess it sits in, but I have to get this tilt deal down to 1 degree (or less) or I know it's going to drive me nuts. Any suggestions from the peanut gallery would be well received.
michaelwalsh is online now
post #53 of 54 Old Yesterday, 03:19 PM
labboypro's Avatar
Liked: 24
Originally Posted by michaelwalsh View Post
I bought the Cheetah APDAM3B articulated mount for my 42" LG (weighs just 30lbs) and am having trouble with the arms sagging that appears to translate into tilt at the TV's screen...
See my posts #25 and #41 on my last 2 (AND LAST EVER) experiences with Cheetah. Absolute garbage. My "solution" was to rework the mounting studs into an angle to offset the sloppy sag of the crappy Cheetah product. Never again.
Either toss your Cheetah in the garbage and try something else or keep stacking spacers in it until you get ahead of the saggy joints.
post #54 of 54 Unread Today, 03:02 AM
LOL! I'm not quite that down on the Cheetah mounts at this point. I did tighten up the arm joints, particularly the ones in the mid-section, since that's where I seemed to have the most going wrong, and I've now erradicated the resultant tilt in the mount's front plate.
I'm still a bit perplexed why the 30mm worth of spacers are still necessary to push out the bottom of the TV, since the back of it is essentially flat, but I'm not an engineer and I now have a screen at zero degrees tilt anyway, which is what I was after, so I'm going to let it go.
