3M-50 wifi question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-30-2013, 03:16 PM - Thread Starter
Hunted Duck's Avatar
I just purchased this thermostat and I know I need the c wire but I don't have a c wire spot on my board in my furnace. It s 5 wire setup with a blue wire, white wire, yellow wire, green wire and red wire. I'm not sure I need the blue wire cause I don't have a heat pump. Any suggestions on hook up?
Thanks, Jeff
Hunted Duck is offline
post #2 of 5 Old 03-30-2013, 03:28 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
No disrespect meant, but what do the instructions say?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 5 Old 03-30-2013, 06:50 PM - Thread Starter
Just said to hook up the c wire on the board but mine dosent have one
post #4 of 5 Old 04-01-2013, 10:16 AM
Sir Meili's Avatar
Quoted: 40 Post(s)
I believe the "c" wire is the common wire needed to supply power to the unit (I have the same thermostat). If you aren't sure if you have the correct wires, you could call an AC company to come out and check and if needed add a c-wire, or like they did in my case (when I had the new AC installed), just run a new set of AC wires to the thermostat.
Sir Meili is offline
post #5 of 5 Old 04-01-2013, 04:24 PM - Thread Starter
Thanks. Do you like the thermostat?
