Epson 8350 Not Supported Message - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-30-2013, 09:22 PM - Thread Starter
gbotri's Avatar
Just moved into a new house that has a dedicated theatre room. Running the following:
Epson 8350 projector
Yamaha RX-V573 Receiver
Samsumg BD E5400 Blu Ray player
TV works fine, not problems. Great picture, great sound.
Blu Ray movies work perfectly. Again, great picture, great sound.
DVDs will not play. The screen flashes pink colors, dots and eventually the projector says "not supported."
If I plug the Blu Ray player directly to the projector, both Blu Ray and DVD work perfectly. Seems like an issue with the receiver. Someone I talked to said that it's related to HDMI incompatibilities and I either need a higher end Blu Ray player or a signal restoring device. I am new at this. Can anyone help?
gbotri is offline
