Where to put speakers [with pictures!] and 6.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-01-2013, 09:16 PM - Thread Starter
Montesinnos's Avatar
Hello folks,
I'm setting speakers in my condo and I'd like some advice regarding back speakers.
I have 3 pairs of Polk RC85i and I am (will be using) them all of the channels.
What would you suggest me to put the back speakers? Check attached photo of the room. It appears I have 3 options:
RED - Side walls (very small on the right side, though)
GREEN - High by the vaulted ceiling
YELLOW - Right by the person's ears
In addition, since RC85i's are only sold in pairs, I have an extra one (came with the center speakers). Should I just plugged it as a surround back speaker? The 6th channel? Or that's not worth it?
Full Album: http://imgur.com/a/lVGjK#2
Thank you so much!!!
Montesinnos is offline
post #2 of 3 Old 04-01-2013, 10:54 PM
Neilsy's Avatar
Hi. Given the speakers are bookshelves I think the red positions would be best for surround ambiance as your photo appears to show the red circles are in corners. It will give me presence and dispersion. Yellow is too close to listener - I used that positioning once and was not very enveloping unless perhaps you had di or tri-pole surrounds.
Hope that helps!
-- 133" AT 2.35:1 Screen -- JVC X500 -- Oppo UDP-205 -- Cambridge 650R -- 2x KlarkTeknik DN360 G-EQ -- Emotiva XPA-5 -- 3x JTR Triple 12; L,C,R -- 3x Velodyne DD18 + DD15 --
Neilsy is offline
post #3 of 3 Old 04-01-2013, 11:00 PM - Thread Starter
Hope that helps!
However, the speakers are in-wall, not bookshelf.
But I agree with you. Yellow is too close.
