Soundbar subwoofer placement question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-05-2013, 01:30 PM - Thread Starter
vettegofast's Avatar
Hello all,
I just got a Samsung hw-e450 soundbar w/ wireless subwoofer. My TV is mounted above the mantle, so I put the soundbar sitting on the mantle itself. I then put the subwoofer in the corner of the room. What is the best way to face the driver and port for the best bass reflection? I am trying the port towards the wall and towards the corner. Can someone tell me the best position? My living room is apr 16 by 27.
Also, if any of you have this model, what settings do you use for the best sound? I am using Cinema right now. Sounds pretty good.
vettegofast is offline
