Speaker placement help needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-17-2013, 01:55 PM - Thread Starter
vipervick's Avatar
Quoted: 64 Post(s)
Liked: 33
Greetings!
I am moving from San Diego to the San Francisco Bay area and purchased a home in a new development. My new Great Room is giving me challenges in the placement department. Currently I have a 19' x 14' living room that works really well. I have a wall unit entertainment center on the 19' wall and surrounds hanging on the back wall.
The new place has a bigger room, with a fireplace right in the middle of the wall where the TV is going. There doesn't really seem to be anywhere to put the center speaker or my audio components. And I think the back wall is too far back to hang the surrounds.
The pictures are NOT my house, but the model. My furniture is similar, but not what you see.
Onkyo TX-NR 5007
Oppo BD-83
AT&T U-verse
Apple TV
Wii
Aperion Intimus 6T's
Aperion Intimus 6C
Aperion Intimus 4BP's
SVS PC-13 Ultra
_________________________________________
The accumulated filth of all their sex and murder will foam up about their waists and all the whores and politicians will look up and shout "Save us!"... and I'll whisper "no."
vipervick is offline
post #2 of 8 Old 04-19-2013, 05:59 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
If I were setting up in that room, I would place the screen, LCRs on the opposite wall. Where those 3 framed units are.
Its never a good thing to have the screen above a FP. To say nothing of the screen being way too high.
And when you are viewing the screen, you are never going to have the FP lit...it would be too distracting.
So I would place two sets of seats, with some facing the FP and the rest facing the other direction for TV viewing.
Plus that wall gives you plenty of room for everything for the A/V.
That model home is so typical when it comes to placing TVs or audio. Very little to no thought on how it should really be setup.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 8 Old 04-19-2013, 01:30 PM - Thread Starter
vipervick's Avatar
Quoted: 64 Post(s)
Liked: 33
Yeah, but that is the main reason the TV is going over the FP, WAF. My current house, the FP is behind the TV viewing area and my wife hates it. I have to deal with this set up.
Here is a pic of my current set up.
post #4 of 8 Old 04-22-2013, 02:45 PM
BeerParty's Avatar
Originally Posted by vipervick View Post
Do you have access from the other side of the fireplace wall? Just from looking at the above picture, you might want to consider putting the TV in the corner (between the fireplace and the windows on the right) and putting your AV equipment to the left of the fireplace. Not ideal from speaker placement I know, and you would need new AV furniture, but it looks like you'll need new AV furniture anyway.
A floor plan would make giving advise easier.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #5 of 8 Old 04-22-2013, 11:09 PM - Thread Starter
vipervick's Avatar
Quoted: 64 Post(s)
Liked: 33
Working with what i have... The center will have to go above the TV there, R&L can go on either side, and sub will go on the side with the corner. It's the surrounds I am having the most issue.
I need symmetry and a corner placement is illogical. Not to mention WAF ugh...
post #6 of 8 Old 04-23-2013, 03:21 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Well, looking at the model picture of the screen over the mantle, I would say there might be enough space for a low profile center speaker.
With all that glass I can see the problem with the surrounds. Other than placing bookshelf speakers on stands.
And what corner placement are you referring to?
4DHD is offline
post #7 of 8 Old 04-24-2013, 07:56 PM - Thread Starter
vipervick's Avatar
Quoted: 64 Post(s)
Liked: 33
This corner placement suggestion...
post #8 of 8 Old 04-27-2013, 05:20 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Setting up an audio system on the diagonals of a room works very well. As far as removing the early reflections as the walls are @ 45* to the main speakers (not in-walls/on-walls, obviously).
You say your wife does not like your current setup, with the FP the opposite wall...have you given any thought of placing the soundstage @ 90* to the FP? You would be sitting with your backs to the kitchen.
4DHD is offline
