Tilt Down Plasma Mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-21-2013, 09:05 AM - Thread Starter
gaspower's Avatar
Hello,
I am in need of a tilt down plasma mount. Not sure if tilt down is correct, but I need the plasma to lay flat against the ceiling when not in use and I can pull down when needed. I do not need a motorized version. Everything I see is motorized and for the little use, no need for the expense of a motorized version. Thanks for the help.
JR
gaspower is offline
post #2 of 4 Old 04-22-2013, 05:12 AM
LINDW4LL's Avatar
Maybe search "flip down TV mount".
LINDW4LL is offline
post #3 of 4 Old 04-25-2013, 08:07 PM - Thread Starter
gaspower's Avatar
Thank you For the post.
JR
gaspower is offline
post #4 of 4 Old 04-29-2013, 05:30 PM
kelton325's Avatar
I am using this - I'm happy with it. You can tilt it to be straight up & down or 15 degrees forward. It's about 10 degrees forward in the pic I believe.
http://www.amazon.com/dp/B000NMFCIA/ref=pe_175190_21431760_M2C_SC_dp_1
kelton325 is offline
