NEED SOME HELP AND ADVICE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 04-21-2013, 11:11 AM - Thread Starter
tkarns24's Avatar
I have a budgeted HT system, That i am planning on upgrading,here is the list of what i currently have
52" Sony Tv
Sony Avr
Polk DSW micro pro 2000
fluance AVBP2 bipolar surround
Custom built 60" LCR sound bar
I want to upgrade
1pair of Bookshelves for my LR
Upgrade sub or add a secondary
upgrade surround speakers maybe matching the fronts
Here are some questions i have .
can i mix speakers?
can i use my lcr as a Center Channel
All advise is appreciated
tkarns24 is offline
post #2 of 22 Old 04-21-2013, 02:03 PM - Thread Starter
tkarns24's Avatar
nothing no help
tkarns24 is offline
post #3 of 22 Old 04-21-2013, 04:00 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2898
Rather than mixing speakers, especially across the front soundstage, why not get 3 of the same speaker for better consistency as sounds move from left to right. Three of these Fluance bookshelf speakers would be a good replacement for your soundbar.
Sanjay
sdurani is offline
post #4 of 22 Old 04-21-2013, 06:23 PM - Thread Starter
tkarns24's Avatar
I don't want to replace my sound bar like i said it's a very unique piece
tkarns24 is offline
post #5 of 22 Old 04-21-2013, 08:15 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
So, what's the question?
You want to replace your LCR sound bar, but don't want to? More details on the sound bar may help.
A different manufacturer for the rears isn't a problem.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 22 Old 04-21-2013, 09:00 PM - Thread Starter
tkarns24's Avatar
I'm sorry for the confusion . My sound bar was built by a friend who is a sound engineer. That was before he got injured in iraq .I thought i might be able to use it as my center channel only and 4 more speakers to it. If i can't really do that than i will keep the LCR and just replace my surrounds as they scratch sometimes when playing movies. I hope that this clears some things up.
tkarns24 is offline
post #7 of 22 Old 04-22-2013, 03:48 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I understand the importance to you, of keeping the sound bar.
Is this custom sound bar fed by 2 or 3 channels from the amp/AVR?
What processor or AVR are you using? Has audio calibration been done?
Neurorad is offline
post #8 of 22 Old 04-22-2013, 04:04 AM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
Exactly what all kind of hookups does the soundbar have? Is it just strictly + and - ?
What model is the Sony AVR?
What model is the Sony TV?
What is your budget?
Licence to Kill
Bond 007 is offline
post #9 of 22 Old 04-22-2013, 06:57 AM - Thread Starter
tkarns24's Avatar
It is currently fed by 3 channels from the AVR
Sony str dh 810
yes i did calibrate, not sure though if i got it all right
tkarns24 is offline
post #10 of 22 Old 04-22-2013, 07:00 AM
Bond 007's Avatar
Liked: 1907
Your budget is unlimited?
Licence to Kill
Bond 007 is offline
post #11 of 22 Old 04-22-2013, 07:00 AM - Thread Starter
tkarns24's Avatar
AVR sony str dh 810
TV sony NX 800
1500.00
tkarns24 is offline
post #12 of 22 Old 04-22-2013, 07:02 AM - Thread Starter
tkarns24's Avatar
Your budget is unlimited?[/
lol i wish , i am a medically retired so i have a limited income. but nice one.
tkarns24 is offline
post #13 of 22 Old 04-22-2013, 08:39 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Do you know if all 3 speakers within the sound bar are the same?
If the answer is yes, I think you could wire the 3 sound bar speakers together to act as a single center, and use other speakers for fronts.
One would usually wire 3 speakers in a combination of series and parallel, to keep the impedance near the optimum level. The wiring would look like this:
Speaker #3 in that diagram would be the 'center' speaker, of the sound bar.
Someone, please correct me if I'm wrong.
Neurorad is offline
post #14 of 22 Old 04-22-2013, 08:41 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Another option would be to just use the center channel of the sound bar, and leave the other 2 speakers unused.
Would be nice to see a 'spec sheet,' on that custom sound bar.
Neurorad is offline
post #15 of 22 Old 04-22-2013, 11:27 AM - Thread Starter
tkarns24's Avatar
Yes they are all the same ,and that is what i would like to do as it would give me i think a broader dialogue and action sound stage if that makes any sense. But since i can't make matching set for the other 4 speakers not sure if i can ever get it right.
tkarns24 is offline
post #16 of 22 Old 04-22-2013, 12:35 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Find a store with a selection of speakers and a good listening room, and see if they'll let you bring in the custom LCR to test with. You'll definitely want to attempt to timbre match the L/R speakers to it - the surrounds will be less important, but figuring out the mains will likely lead you to that answer - the dealer can help with that, too...
Jeff
jautor is online now
post #17 of 22 Old 04-22-2013, 01:40 PM - Thread Starter
tkarns24's Avatar
Jeff
Yea i thought about doing that , just not too many in palm coast fl
tkarns24 is offline
post #18 of 22 Old 04-22-2013, 02:30 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You need an experienced ear to help with the speaker decision. In my opinion, it's worth the added cost to buy in a dealer showroom, compared with online. Pick a budget, and decide how much money it's worth to you to get your new fronts timbre matched to the sound bar.
Drive to Jacksonville.
Call Southern Cinema Design, in St. Augustine, to find out if they have a showroom yet (coming soon) (by appt only).
Be careful who you trust - you need someone with a good ear, and not just a salesman.
Neurorad is offline
post #19 of 22 Old 04-22-2013, 02:45 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Digital Sound & Satellite may be another option, for a demo room.
Neurorad is offline
post #20 of 22 Old 04-22-2013, 03:17 PM - Thread Starter
tkarns24's Avatar
Hey thanks much i will look into that.
tkarns24 is offline
post #21 of 22 Old 05-12-2013, 05:24 PM - Thread Starter
tkarns24's Avatar
Hey guys i am considering changing the Fluance surrounds that are bipole for maybe some dipole. since my my movie area is so wide bcuz of the open floor plan. Can my bipole do the job or is my idea on point
tkarns24 is offline
post #22 of 22 Old 06-21-2013, 11:11 PM - Thread Starter
tkarns24's Avatar
Hey guys well after much heart ache and many hours of work ,I am ready to share what i have been working and and the solution to my surround speaker people
Ok this is before
Here are some of the build and final product
End Table /Lamp stand / Speaker stand
Ok Well there we go guys, I still have a few things to finish, but this is what i have been up too lately.
tkarns24 is offline
