Where to mount TV in living room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-21-2013, 03:13 PM - Thread Starter
kaitlyn2004's Avatar
I'm upgrading my 42" LCD to a new 60" LED TV - exciting! As part of this I want to mount the TV, but that's where I'm running into trouble.
This is my floorplan:
Basically the options are the right wall or the left wall. I originally had it set up on the right wall, with a 3-seater along the left wall and a loveseat along the windows with a side table.
Last week I switched the position of the 3-seater and the TV to see how it is (it's how the previous owners laid out the room). It gives the room a different feel but I'm not sure I like it as much. For one thing, due to the angles the TV sort of points towards the balcony door - not towards EITHER couch...
The left wall has a "drop ceiling" about 3-4 feet in from the edge of windows for the ducts - this leaves about 69in to the end of the wall, assuming I used it as a divider. It's a bit tight especially if I kept the floorstanding speakers.
On the right wall, there is the fan coil unit + vent, so looking at the TV you've got that sitting right next to it.. so it's not exactly a completely "clean" wall where all you really see is the TV.
What are your recommendations for the best layout/setup? I'm more than happy to answer any questions that may make it easier to help me! smile.gif
Much appreciated
kaitlyn2004 is offline
post #2 of 2 Old 04-22-2013, 05:04 AM
LINDW4LL's Avatar
I would put it on the right wall.
LINDW4LL is offline
