Watts/Channel in Speaker vs Watts/channel in Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-29-2013, 09:50 PM - Thread Starter
raj3875's Avatar
Hi,
I am planning to purchase a receiver for Definitive Tech ProCinema 800 speaker system. I do have plans of upgrading to 7.1 sometime later . Each speaker has a different recommended amplifier power as below:
ProMonitor 800 (4 each) - 10 – 150 watts
ProCenter 1000 (1 each) - 10 – 200 watts
ProSub 800 (1 each) - 300 watts
I am seeing receivers which can pass different watts per channel like for example some have 100X5 and some like 90x7.
If i buy a receiver which is passes 90watts per channel output should i assume that i am under utilizing the speaker's capacity?
thanks,
raj
raj3875 is offline
post #2 of 2 Old 04-30-2013, 12:18 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
No. The "ratings" on speakers should be read as the "max safe limit". As in, push more power than that, and you can damage the speaker. Some manufacturers will put a 'recommended' amplifier output, but those are just a guideline, too, based on the speaker's efficiency.
The difference in output between a 90W/ch AVR and 100W/ch is trivial. Note that except during really loud playback, you're only driving a small percentage of that total output anyway.
Jeff
jautor is offline
