soundproofing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-31-2013, 05:42 AM - Thread Starter
johnlaw12002's Avatar
SO just moved into a new home, I have my little theater area set up and its rocking however the sound travels very well through the rest of the home any tips on what can be done?, the basement is fully finished,drywall carpet etc..so I am looking to see what i can do with minimal impact on the already finished space.
johnlaw12002 is offline
post #2 of 10 Old 05-31-2013, 08:07 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Sound isolation in HT is normally to keep outside sound out of the theater. If your room is complete, there is little that can be done other than turn down the volume or use in-ear or head phones. Most all sound proofing is accomplished during the building of the room .. i.e. room within a room sealed and isolated. There is a big long thread on sound proofing in this forum or the Dedicated forum, just do a forum search for Sound Proofing.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 10 Old 05-31-2013, 03:57 PM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
Are you sure...
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
post #4 of 10 Old 05-31-2013, 05:34 PM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
The average person that calls us is looking to keep the sound in so they can crank and not disturb.
__________________
Ted
The Soundproofing Company
Ted White is offline
post #5 of 10 Old 06-01-2013, 05:01 AM
ctviggen's Avatar
Quoted: 116 Post(s)
Liked: 32
And there's nothing wrong with that and that should be addressed. If you build the room correctly, you should be able to reduce sound transmission to the rest of the house, too. Personally, I do not care a wit whether sound gets into the home theater, but care greatly about sound getting out. It seems to me though if you address one, you address the other.
Bob
ctviggen is offline
post #6 of 10 Old 06-01-2013, 05:59 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Sorry for the confusion, I as just was reposing what I have read many times in the dedicated home theater threads. Does not matter which way the sound goes, the process of stopping is the same.
Ted please correct the more important portion of the answer I gave to the question, "what can be done after the fact when the room is completed"? From what I know, without rebuilding the room properly it can be rather difficult and almost as expensive with lesser success to try and fix things afterwards. You obviously are one of the experts on sound proofing and I would appreciate any insight you could provide as I do not like to give bad answers to questions. Adding a second layer of dry wall with green glue on walls and ceiling, sealing all electrical boxes and all air passages, installing mufflers in ac runs and returns etc are effective but without structural isolation (room in a room clips and channels ) the effectiveness is greatly reduced.. Do I have this part correct?
The OP was also asking about "I am looking to see what i can do with minimal impact on the already finished space.
So is the answer "there is little that can be done" a correct answer?
Doug
post #7 of 10 Old 06-01-2013, 06:08 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
If your wall framing is 24" on center studs, then applying more drywall and damping compound can provide satisfying improvement. If the studs are 16" on center (likely) then applying more drywall and damping compound will not improve things as much. To be clear, this technique on 16" studs will improve performance, but not much. Could easily be seen as a waste.
The other consideration is to build a completely new wall 1" away from the old one. Still not as ideal as removing the original drywall, but some folks have lead or asbestos and would rather leave well enough alone.
__________________
Ted
post #8 of 10 Old 06-03-2013, 08:17 AM
ASolutions,Inc.'s Avatar
If you are not looking to open the walls back up, applying a damping compound like Green Glue and an additional layer of drywall to the walls and ceilings will help block transmission of sound in and out. Make sure you seal all corners with acoustical caulk after. And adding acoustical door seal kits can help take care of that weak spot. Good luck!
ASolutions,Inc. is offline
post #9 of 10 Old 06-03-2013, 08:55 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Or you could re-read post #7...
__________________
Ted
post #10 of 10 Old 06-05-2013, 07:23 PM - Thread Starter
thank you for the input. atm i am just going to live with it, maybe down the road i will address the issues but its a new home and ripping out a brand new finished basement so that i can watch movies a bit louder does not make sense for me atm.
