Newbie breaking into the 21st century - AVS Forum | Home Theater Discussions And Reviews
Old 06-03-2013, 03:44 PM - Thread Starter
kdkrone's Avatar
(Moderator, if this is not the place, please move my post)
We have just purchased a new home--literally. We had been living for many years in an adobe home with limited options for A/V. Now, we are moving into a home that is brand new with, unfortunately, limited wiring in place.
Here is where I come from: 28" inch deep cabinets to house the old style TVs, but with a 47" Samsung LCD TV. My receiver is a 20+ year old Onkyo. The last speakers I purchased were AR speakers which had been rebuilt once while I had them during their 30 year life and which we just gave to Goodwill. What I see in the new house is a shallow cutout in the wall with a TV barrel connector, a double receptacle and about a 1" conduit running to a closet.
So what I get from all this while I have been asleep for the last couple of decades is that instead of hooking all of my equipment into the TV connectors, now I need to purchase an A/V receiver with lots of hookups, then I plug my "hidden" pieces into the A/V receiver in the closet from whence one HDMI (or two) cables run to the TV hanging in the other room. I assume, then, I would need an IR receiver, also running through the conduit back to the closet with some kind of medusa-head of emitters to the DVD player, a ReplayTV (I told you my equipment was ancient) , a SlingBox, a cable box (I think that is it). I will also need some speakers with the limitation being that my wife will not allow any free-standing speakers.
So, first, is that the basics of how things are to be set up? If so, then I would appreciate if people would be kind enough to recommend some websites/equipment that I should research.
1, speakers (ceiling/wall, wireless woofer??)
2. A/V receiver. I have budgeted up to about $800 for this, looking for quality and trying to fend off obsolescence...
3. IR equipment. Is there a big difference? Who makes reliable and relatively unobtrusive receivers and emitters? Is the receiver hung on the TV? Can it be powered from a cabinet about 25 feet away?
That is for starters. What else should I be considering for initial setup? I have about a terabye of movies, some as .iso files and others in their native file structure. Is there a receiver that can search my home network and play them, or would I need a small computer to do that? If I were to need a small computer and presumably a program, where should I start my research?
I'll tell you, I feel like Rip Van Winkle... I don't mind at all doing the research, but I would appreciate knowing where to begin.
Ken K
kdkrone is offline
Old 06-03-2013, 08:17 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Now that's lucky! I thought you were in trouble until we hit the conduit... Now you're set!
Yes, a modern AVR does an excellent job of handling all the analog and digital video inputs and switching, plus Internet audio sources like Pandora. One HDMI cable to the TV.
The AVS Speaker forum.
The AVS Receivers forum.
$800 will buy a quite nice AVR these days - even $400-500 will get you all of what you need and then some you didn't know you wanted...
Difference is all in the receiver, both performance and "style". If your new Samsung TV is an LED set, no problem - if it's a CFL-based LCD (meaning, not an LED-powered), you might run into IR interference issues with cheap IR receivers. Monoprice has an absolute dirt cheap IR repeater kit (<$20) that's ready for a 3.5mm connector cable (readily available in 25' lengths) between receiver and the emitter package.
No AVR will do it, as there's too much legal trouble involved. You'll need a small media streamer - read all about them in the AVS Media Streamers forum or the HTPC forum.
Jeff
jautor is offline
Old 06-04-2013, 08:26 PM - Thread Starter
kdkrone's Avatar
Thanks for all the effort you put into your reply, Jeff. I have my work cut out for me, but I should be able to work through it with some help. I will visit the different forums and figure out what will work. One problem I may have is that I am quite wedded to my ReplayTVs (dvrs), and the best output is only composite connectors. It takes s-video and perhaps that is all I really need since the output is low res. I will look for some 50 foot cables to feed through the conduit.
Thanks again. I am sure I will be back once the dust of the move next week settles.
Ken K
kdkrone is offline
Old 06-05-2013, 11:28 AM - Thread Starter
kdkrone's Avatar
Jeff,
WRT the monoprice ir repeater that you mentioned (I assume it is this one: http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011009&p_id=9895&seq=1&format=2):
1. Is there likely a problem with using a 25' extension cord for the run back to my AV cabinet? (problem with the total length of the run)
2. While it says that this particular IR repeater has only 4 emitters, is it likely that exchanging one of the single emitters for a multiple head emitter would not be successful because of whatever power draw it may add? I have the AV receiver, a cable box, the ReplayTV, a Roku, AppleTV (not sure why I have the duplication except that my brother in law gave us the AppleTV) and a DVR. (I am not sure which is controlled by what at the moment and I may not actually need all of them controlled from the TV but the question is just more general about having more than 4 emitters and whether it is your guess that such a repeater would be able to handle a multi-head emitter.
Ken K
kdkrone is offline
Old 06-05-2013, 12:43 PM
jautor's Avatar
Liked: 777
Yes, that's the one. And you'll be fine with a 25' 3.5mm STEREO extension cable (you need the 3-conductor stereo plug/wires, not a mono "emitter" extension cable).
That kit comes with two, double-emitter cables. But it has a total of 5 emitter outputs, so you can just add 3 more emitters (single or dual).
Jeff
jautor is offline
Old 06-05-2013, 02:50 PM - Thread Starter
kdkrone's Avatar
"so you can just add 3 more emitters (single or dual)."
Are emitters mix and match amongst manufacturers or should they be the same manufacturer? I have some that came with my ReplayTV that are on a 2" bracket so that they shoot up or down about 45 degrees at the equipment. I would look for more of those if the manufacturer doesn't matter.
Thanks again
kdkrone is offline
Old 06-05-2013, 04:01 PM
jautor's Avatar
Liked: 777
Emitters are pretty universal. Some may work better than others, most of the differences I've noticed have been in style / form factor. In a hidden system, none of that matters, really... Certainly use ones you have lying around before buying new ones!
jautor is offline
