Help, new house, where should I put the TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-08-2013, 11:44 AM - Thread Starter
detzx's Avatar
I miss my dedicated media room but until I finish the renovations on the main floor I can't even start that project which will probably be 18 months. So, I need to figure out how to watch movies/tv until then. I hooked up our 32" for now since it fit but I can't read it sitting 18' away so I need the 55' or 70' but I can't figure out where to put it. Here are my best shots.
I could possibly fit the tv where the current 32" is but it might look odd at that angle. The other option is the other corner but I don't think I can fit much there. I don't want it above the FP.
First three are me sitting on the couch in a normal position. The other are panoramas to get a feel for the room I'm working with.
detzx is offline
post #2 of 4 Old 06-10-2013, 07:54 AM
kriti gautam's Avatar
try to put it at the front side of your sofa
kriti gautam is offline
post #3 of 4 Old 06-10-2013, 08:06 AM
NickTheGreat's Avatar
Quoted: 424 Post(s)
Liked: 301
Could you put it on the wall to the left of if you're sitting in your couch currently? Looks like a wall between the living room and kitchen?
I personally like TV's on the fireplace, but I'm not sure I'd like it in your case
NickTheGreat is offline
post #4 of 4 Old 06-10-2013, 08:09 AM - Thread Starter
detzx's Avatar
That big bay window in front would then have the couch in front of it...kind of looks odd.
detzx is offline
