Does my Media area need its own circuit? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-21-2013, 09:57 AM - Thread Starter
brazosdog02's Avatar
Quoted: 13 Post(s)
I believe the electrician wired the whole room together. I was thinking it might be better to have the plugs that will service my TV, blu-ray, and Audio stuff on their own 15A circuit? Yes or not? right now, it will simply require running a single 14g wire back to the panel and hooking it up. Once drywall goes up, not so much. But for my setup, is there any reason to even split those devices off the main circuit for the room that has lights/outlets?
brazosdog02 is offline
post #2 of 10 Old 06-21-2013, 10:10 AM
jautor's Avatar
Quoted: 1327 Post(s)
Liked: 850
I didn't do this in my family room, and actually ran into a bit of trouble. With all the room lights on, bringing the amp on (old amp with no in-rush current limiting) would trip the breaker.
As you said - it's easy/cheap to do now, neither is true once the drywall is up. You may be perfectly fine depending on how many other rooms/walls/lights are in that circuit, but given the chance, a circuit here would be prudent. I don't think anyone would claim that to be overkill.
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
post #3 of 10 Old 06-21-2013, 11:04 AM - Thread Starter
Quoted: 13 Post(s)
Im debating it because there are literally two outlets on that wall, LOL. The TV will be served with a power bridge. There will be a surge protector/condition plugged in near the floor and everything will be plugged into that. Didn't know if it was even really necessary from a 'noise' standpoint or something.
post #4 of 10 Old 06-21-2013, 12:06 PM - Thread Starter
Quoted: 13 Post(s)
wont a single 15 amp circuit be more than enough for a 5.1 surround system, 65" TV, and blu ray player? I could have a few extras on it later, but its a media room, not a dedicated HT.
post #5 of 10 Old 06-21-2013, 01:32 PM
jautor's Avatar
Liked: 850
It's more than enough for that gear - the concern would be what else *besides* that gear is on the circuit. That gear alone is probably 3-5 Amps, with some peak during startup or really loud moments. If it's just the outlets/lights in one room, you're fine. If the circuit also feeds another room, more walls, etc. - then you might want to consider a dedicated circuit, but from your description, it's probably ok as is...
jautor is offline
post #6 of 10 Old 06-21-2013, 01:34 PM - Thread Starter
Quoted: 13 Post(s)
Its got a bunch of outlets, can lights and possibly a ceiling fan on it.
post #7 of 10 Old 06-21-2013, 01:54 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
If it makes you feel better add another circuit!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #8 of 10 Old 06-24-2013, 05:33 AM
kamleshg's Avatar
I had the same questions when i did my circuits, thought i opted for 20A. And i have about 7 other outlets on that circuit.
Most of what i heard from electrician was that if it dont suck or blow, it wont need much.
So like other posters said, you should be good, but if you want/can go ahead...
kamleshg is offline
post #9 of 10 Old 11-06-2013, 12:49 PM - Thread Starter
Quoted: 13 Post(s)
My setup ended up being 5.1 system, Denon X2000 receiver, Rythmik 12" subs and a 75" TV.
I have not hooked up the 'dedicated' 15A circuit, but im thinking my current circuit with lights will still suffice. Any objections? Should I 'enable' the dedicated 15A outlet or just try it as is and see how it does?
post #10 of 10 Old 11-06-2013, 02:33 PM
gec5741's Avatar
Quoted: 202 Post(s)
Liked: 92
I split my outlets into 2 seperate circuits in my media room (still in progress). Then I split my lighting up into 2 seperate ones as well. Then for my PJ outlet I added it's own circuit. I'm carrying this type of theme through out my basement. I have to add a small sub panel because Iv'e filled my main panel but I think it's worth it. Now I am doing this because I can now while building. It may be over kill I don't know but I'd rather be on the safe side rather then have regrets later.
gec5741 is offline
