Are "Level Mount by Elexa" branded TV mounts any good? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-22-2013, 09:56 PM - Thread Starter
lnong's Avatar
Quoted: 57 Post(s)
Liked: 24
I saw this one marked down to $60 at a local store that is closing. The mount is an "adjustable fixed or tilt" mount for flat panels up to 85" and 200lbs. It's heavy and looks sturdy, but I've never heard of this brand. Is it reputable?
TV: Samsung 85" UN85HU8550 (TD01) with SEK-3500
AVR: Marantz SR7010
Speakers: Dynaudio Audience
lnong is offline
post #2 of 3 Old 06-23-2013, 11:23 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Contrary to what some around here would have you believe TV mounts aren't 'rocket surgery' (although many are priced that way). That said, I usually recommend MonoPrice when asked. Plenty of stuff about that brand on Google. wink.gif
PS: Looking at those Google hits it appears to be a UK product. Are you perhaps in the UK?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 3 Old 06-23-2013, 09:20 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I would agree that for most fixed wall mounts, any old cheap mount will be fine, if installed securely to solid wood studs. But, when one has needs for articulating, pivoting, or other specialty mounts, the higher price for name brand is justified. There are large quality differences.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
