Looking for mounting Ideas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-24-2013, 11:44 AM - Thread Starter
SeanU's Avatar
Hey everyone. I'm looking for ideas for mounting a TV in this room :
Mantle is too high for comfortable viewing. I've seen the Down and Out mounting which so far appears to be the best option. Based on the viewing wall, does anybody have any other ideas?
Thanks - Sean
SeanU is offline
post #2 of 6 Old 06-26-2013, 09:40 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
I'm personally a big fan of above the mantle. And you don't have a lot of options here, if that's the only place to put the TV.
How about in the corner where that armoire lookin' thing is? Or on the wall that the photo-left?
NickTheGreat is online now
post #3 of 6 Old 07-11-2013, 01:54 PM - Thread Starter
SeanU's Avatar
Thanks Nick... the corner mount might be an option. I saw some interesting options here ($$$$) : http://www.inca-tvlifts.com/ .
SeanU is offline
post #4 of 6 Old 07-13-2013, 12:00 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I've seen at least a couple threads in the last 6 months discussing corner mounts.
Search AVS for "corner mount" in quotes.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #5 of 6 Old 07-13-2013, 06:31 AM
ylestrat's Avatar
Hello,
It seems you already have the best option. I am not sure if what you are considering is a articulating mount that would allow to move the TV slightly away from the wall and adjust it up and down to your liking. Otherwise, placing the TV to a different location and reshuffling the room furniture might also be another options depending if the family can live with it rolleyes.gif
Good luck!
ylestrat is offline
post #6 of 6 Old 07-13-2013, 08:42 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
What do the other walls look like?
Neurorad is offline
