Home Theater Setup Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-24-2013, 06:40 PM - Thread Starter
damarco's Avatar
I'm a newbie at this and need some advice/ recommendation on hooking up home theater system. I have an Onkyo HT-R580 system, a ps3, xbox360 and a directv sat box/dvr and a Panasonic GT-50. Do I hook everything to the a/v receiver or should I connect any componenets to the tv? And what about digital optical audio cable. Any help/recomm would be appreciated.
damarco is offline
post #2 of 3 Old 06-24-2013, 07:05 PM
Sonyad's Avatar
Quoted: 194 Post(s)
Liked: 111
Everything should be connected to the receiver using hdmi high-speed cables. You shouldn't have to use the optical cable from what I can tell.
Sonyad is offline
post #3 of 3 Old 06-25-2013, 04:53 AM - Thread Starter
damarco's Avatar
Thanks I'll give a try
damarco is offline
Panasonic Viera Tc P50gt50 Plasma Tv
