Mounting ceiling projector under load bearing steel i-beam - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-26-2013, 02:46 AM - Thread Starter
kevpatts's Avatar
Hey all,
I've bought a HD projector and the room I'm installing it in has been extended out the back with a small 2m extension. Because of this there is an "arch" where the load bearing beam sits a little below the ceiling.
I'm looking to bolt my projector ceiling mount into this. Is it safe to drill 4 small holes through the bottom of the i-beam? I assume I will have to because I wouldn't have though there's enough plaster to support the weight of the projector and mount.
Kevin
Amps: Tag McLaren AV32R-DP, 3x Musical Fidelity P140
Speakers: B&W 604, 601, LCR600, ASW675 Series 3
Cables: Nordost Super Flatline MKIII
Video: Optoma HD25-LV, 140" Black Widow screen
Sources: Custom built XBMC/Plex HTPC, PS4, Xbox 360, FreeSat HD & Saorview HD
kevpatts is offline
post #2 of 3 Old 06-26-2013, 05:27 AM
mndwgz's Avatar
4 bolt holes in the bottom flange will be OK. You can make them an eight bigger for wiggle room if you need to, or even tap them to bolt right to it..
mndwgz is offline
post #3 of 3 Old 06-26-2013, 05:51 AM - Thread Starter
kevpatts's Avatar
Thanks for the info. Tapping them sounds like the best idea, don't want my projector falling!
kevpatts is offline
