Looking for good screen solution - AVS Forum | Home Theater Discussions And Reviews
Old 06-30-2013, 03:05 PM - Thread Starter
Kryptyx's Avatar
So I'm new to the whole projector scene and have already decided on the BenQ W1070. My problem now is figuring out the most ideal screen for my room. I live in an apartment, fairly spacious but still an apartment. I'm looking for a 120" screen that won't cost too much. I can somewhat control the lighting, I'm putting up blackout curtains in the living area. I've been debating on a few different Elite Screens. From my understanding higher gain means the screen will be brighter. So here are the choices I have:
ER120WH1 - 1.1 gain Cine White $300 - Amazon
ER120GH1 - 1.8 gain Power Gain $380 - B&H
ER120DH2 - 2.0 gain Air Bright 3D2 $430 - CostCaptain
My buddy has the same projector setup in a different apartment (same complex) as me and he currently has nothing. It projects on an off-white wall but still looked pretty decent although it wasn't that great during the day (a lot of ambient light).
Anyway, any advice or help would be greatly appreciated. I would like to keep the cost around 400 or less. I will be using 3D but not nearly as much as 2D. Seating is about 10ft away from the wall. Thanks!
Kryptyx is offline
Old 06-30-2013, 03:18 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Give the AVS guys a call, the can get you a decent screen at the best price
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 07-08-2013, 01:12 PM
CheYC's Avatar
Quoted: 35 Post(s)
Liked: 56
Given the brightness of the 1070, a 1.8 or 2.0 gain screen might be serious overkill unless there will be a fair amount of ambient light (not sure how blackout your curtain will actually be).
CheYC is offline
Old 07-08-2013, 05:38 PM - Thread Starter
Kryptyx's Avatar
I went with the Cine White with it's 1.1 gain. The projector will be here tomorrow. The curtains did a good job blocking out a good portion of the light. I was reading a lot of reviews that said the higher gain screens made the picture look off in the corners versus the center and that the 1.1 gave a better distribution of light.
Kryptyx is offline
Benq W1070 1080p 3d Projector
