What screen size. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-15-2013, 02:50 PM - Thread Starter
Wired4Speed2's Avatar
I am looking at 110-120 inches, just worried 120 might be a hair to big for the space. 8' tall after the drop ceiling installed. width is 15.5' and length is approx 20'. The screen will be centered with the room vs what I had in the drawing. Epson 8350 will be the projector.
Really short notice since I will probably order the screen tonight or tomorrow.
Thanks ahead of time.
Wired4Speed2 is offline
post #2 of 5 Old 07-15-2013, 03:00 PM - Thread Starter
post #3 of 5 Old 07-15-2013, 03:00 PM - Thread Starter
post #4 of 5 Old 07-15-2013, 04:17 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
Get a sheet or some photographer's backdrop paper and test out the size(s) before you spend money on the screen... Lead time on screens is minimal, worth the check before you plunk down the money.
My front row is ~10' as well, and I have a 108" screen (at 1.85:1) - I wouldn't go any larger than that, personally, but that will depend a bit on preference...
jautor is offline
post #5 of 5 Old 07-15-2013, 10:01 PM - Thread Starter
I setup projector tonight and decided on the 110 inch. Thanks
Epson Powerlite Home Cinema 8350
