Anyone Worked With LED Strip Lighting? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 01-24-2014, 06:51 AM
AuroraGT's Avatar
Liked: 49
I use 2 power supplies with 2 x 5 meters RGB LED strips for each power supply. 20 meters overall. The power supplies are in the tech/projector room. It is dimmable as well and waterproofed. I come from Germany but same here. The offering is just too much! More pictures in my gallery (signature)
AuroraGT is offline
post #32 of 35 Old 01-24-2014, 10:58 AM - Thread Starter
DivinityCycle's Avatar
That is awesome! Are those strips one color at a time? I was looking at some sort of addressable setup, but it gets really expensive and complicated if you want individually addressable RGB LEDs.
DivinityCycle is offline
post #33 of 35 Old 01-24-2014, 11:05 AM
AuroraGT's Avatar
Liked: 49
Thank you! Yes it is always one color at a time. I can set different programs but always one color at a time. Addressable would be nice but just until every friend has seen it. It's too expensive for normal usage.
AuroraGT is offline
post #34 of 35 Old 01-27-2017, 04:31 PM
GPowers's Avatar
Quoted: 43 Post(s)
Liked: 49
Anyone done DMX control of digital addressable LED light strips? Looking for information on IC chips and Controllers/decoders.
GPowers is offline
post #35 of 35 Old 01-28-2017, 08:33 AM
ctviggen's Avatar
Quoted: 116 Post(s)
Liked: 32
Originally Posted by j0hnnyyyy View Post
i just use white. i dont have a good camera so it always comes out different and looks like a different color on pictures
I've been using these for my TVs:
Behind TV LED
I get them with the controller for USB that automatically turns them on and off when the TV turns on and off. I have also purchased the dimmer, but I never used it with the previous TV. I bought a new version for my new TV, but haven't installed them as of yet.
If your TV is calibrated to 6500K (the standard for movies anyway), you want the LEDs to be about the same color temperature (the "K"). I believe these are about 6000K, which is good.
Bob
ctviggen is offline
