Dan's Contemporary Basement Renovation/Game Room/Home Theater - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 137 Old 01-28-2014, 02:38 PM - Thread Starter
daaaaaan's Avatar
They are some type of ceramic tile that I got from a local pro source. Sorry, I dont have the exact name, but are very common.
daaaaaan is offline
post #122 of 137 Old 01-28-2014, 05:43 PM
gbdmbfan3's Avatar
first off, beautiful basement.....you did a great job! when you were building your bar frame, I notice in the pictures you installed black (shim like) material every foot or so...i assume to hold the granite once installed....could you let me know where you got those pieces as well how you installed them...thanks!
gbdmbfan3 is offline
post #123 of 137 Old 01-28-2014, 07:32 PM - Thread Starter
daaaaaan's Avatar
Its to provide extra support for the granite, its over-engineered, but if anybody ever decides to crawl up on the counter top, it will hold their weight (body shots, cough cough) hahah..
They can be found here:
http://www.countertopbracket.com/
daaaaaan is offline
post #124 of 137 Old 01-29-2014, 04:46 PM - Thread Starter
daaaaaan's Avatar
Thanks to everybody who encouraged me to replace my speaker. I got the klipsch installed, and not only does it look better, but sounds better....not THAT much better, but vocals "fill" the large open space better. $250 better? Not sure about that, but its staying.
daaaaaan is offline
post #125 of 137 Old 01-29-2014, 06:11 PM
Noah's Avatar
Good to hear you can detect some improvement, even if the ROI isn't overwhelming. Did you re-run the Bose auto-setup routine? If not, that may help, too. I'm not sure how much manual control you get with a system like this, but I would play with levels and crossover points if it gives you the option.
It certainly does look better.
Noah is offline
post #126 of 137 Old 01-30-2014, 06:59 AM - Thread Starter
daaaaaan's Avatar
Yes I did re-run the auto-setup routine (which actually works pretty well, when you compare it before-to-after). You get some manual control, but not to the point of crossover points. The voices are more defined, but at the same time more centralized, and what I mean by that is you can now easily tell the voices are coming from way below the TV. In my set-up I have no other choice but to have the speaker located there. The bose was more of a broadcast sound, so it wasnt so easy to disseminate the speaker location with your ears.
daaaaaan is offline
post #127 of 137 Old 01-30-2014, 12:08 PM
Jester435's Avatar
Quoted: 24 Post(s)
Liked: 75
are you able to quick connect and disconnect the bose center and klipsch center watching the same show, so you can do a true comparison. I bet you would notice a dramatic difference.
When I went from a soundbar to a 3.1 setup the difference was night and day.
Jester435 is offline
post #128 of 137 Old 01-30-2014, 12:16 PM
PolishDude's Avatar
Quoted: 14 Post(s)
It may be severely limited the output out of the center speaker so it does not overpower the Left and Right bose speaker?
PolishDude is offline
post #129 of 137 Old 01-31-2014, 11:36 PM
Noah's Avatar
That's not altogether a surprise. Larger drivers have narrower dispersion. This is why many speakers are made with a waveguide on the tweeter. The waveguide makes the tweeter's output more directional so that the tweeter and woofer have more similar on/off axis characteristics.
So, having switched to the Klipsch with it's larger woofers (and horn/waveguide on the tweeter), you're able to localize the source of the sound a bit easier as compared to the Bose, which probably used 2 smaller "full range" (using the term loosely) drivers.
Noah is offline
post #130 of 137 Old 02-14-2014, 12:29 AM
value's Avatar
Your a pro looks great. Clean design !
value is offline
post #131 of 137 Old 02-18-2014, 12:47 AM
MrMag512's Avatar
Dan I love the basement and what you did to it...The only thing I see that could help out is getting a receiver that has atleast two HDMI outputs which would eliminate the splitter, and your extremely losing out on audio going BOSE reason being BOSE does not support audio codecs such as DTS HD and Dolby True HD that the PS4 delivers via blu-ray.  P.S. if your looking for a replacement for all those remotes try either for a high end replacement URC Remotes or for a lower end replacement Logitech Harmony Remotes. see ya
TV - Panasonic 60GT50
Source - Pioneer Elite VSX-42
Speakers - Def Tech Promonitor800 L & R, ProCenter 1000, ProSub800
Consoles - Xbox One, Xbox 360, PS3
Remote - Harmony 650
Cables - Audioquest Chocolate HDMI's, Sub-X, X2 Speaker Cable and NRG X(Power Cable For TV)
MrMag512 is offline
post #132 of 137 Old 02-21-2014, 12:42 PM - Thread Starter
daaaaaan's Avatar
I have Chad B scheduled to come tomorrow morning in hopes to get the max out of my projector/TV. I'm having some motion issues with the PJ that I hope ChadB will resolve...and from what I have read he seems to be the best around.
daaaaaan is offline
post #133 of 137 Old 02-25-2014, 08:05 AM - Thread Starter
daaaaaan's Avatar
I highly recommend having Chad B calibrate your stuff....he took my projector & TV to the next level, everything looks wayyyyyyyyyyyyy better than what it did before!!!!!! Was very professional, showed up exactly on time. I couldnt say better things about him!
He even didnt make fun of my bose system!
daaaaaan is offline
post #134 of 137 Old 03-04-2014, 10:44 AM - Thread Starter
daaaaaan's Avatar
Here are some pics post calibration -
daaaaaan is offline
post #135 of 137 Old 03-04-2014, 01:27 PM
Done Deal DR's Avatar
Quoted: 98 Post(s)
Liked: 146
Great build Dan! I've really enjoyed watching it progress through the stages. smile.gif
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
post #136 of 137 Old 07-09-2014, 03:36 AM
Liked: 0
Bathroom renovation is the best solution to give a different look to your bathroom.
thomasben is offline
post #137 of 137 Old 07-09-2014, 05:41 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 508
Are there any final pictures of the space that you can post?
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv , Sony Vpl Hw50es 3d Projector , Basement Bar
