Network issues - AVS Forum | Home Theater Discussions And Reviews
Old 07-22-2013, 10:53 PM - Thread Starter
Gingy4's Avatar
I just purchased a Pioneer VSX-70 Elite Receiver. I am trying to connect it to the bet via an Internet cable that is plugged directly into my box, but nothing happens. Can someone help.
Thanks in advance.
Gingy4 is offline
Old 07-23-2013, 12:03 PM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
Thanks in advance.
I'm guessing you mean that you're trying to connect to the Net? what box are you refering to? pictures are worth a thousand words!!!!smile.gif
RollTide2011 is offline
Old 07-23-2013, 02:57 PM
Wired4Speed2's Avatar
Make sure you get a link light on the network adapter. Is the device your plugging into running DHCP if not then your system will not obtain an IP address to communicate on the LAN (local area network). I don't know your device, but I know you have to enable network in the on screen setup menu on some AV receivers.
Wired4Speed2 is offline
Pioneer Elite Vsx 70
