2700 or 5000k Cree ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-24-2013, 08:38 PM - Thread Starter
daaaaaan's Avatar
What is the more popular choice on here for a general game room/home theater set up? 2700 or 5000K Cree lights?
daaaaaan is offline
post #2 of 4 Old 07-25-2013, 03:17 PM
Renron's Avatar
Quoted: 27 Post(s)
Liked: 30
Referring to the "K" color scale 2700k would be on the yellow side, 5,000k would be closer to "daytime" normal condition light, which is closer to ~6,500k. As a Remodeling Contractor I recommend ~3,500k in the Kitchen (makes meats look better, 6,500k makes the meats look "greenish" and unappetizing) and anything around ~5,000k - 6,500k for the rest of the home. Bathrooms and women's vanity area especially.
So, IMO, use a dimmer and go for 5,000k for more natural appearing light.
Ron
"New Member" since 2007....
Renron is offline
post #3 of 4 Old 07-26-2013, 05:45 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Can you try each, and see which you prefer?
Make sure they dim well, with your dimmer. Some LEDs don't dim nicely, with some dimmers.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 4 Old 07-26-2013, 08:08 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
2700K matches incandescent, 5000K is more like daylight. Be aware that dimmable LEDs generally don't shift color toward the reds like filament bulbs do. 3500K is a nice compromise. Most of the fluorescents I buy at work are 3500K.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
