Help: Need some advice on room treatments for HT (with wife set limitations) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-25-2013, 10:46 PM - Thread Starter
zanlation's Avatar
I have completed upgrading the HT equipment in my open living area. I have the following gear:
42" Sony Bravia LCD TV
Yamaha RX-767 7.1 A/V Receiver (pre-HDMI)
HTPC with Asus Essence ST and H6 card with modified OPAMPS
Front LR Speakers Paradigm Mini Monitors v6
Centre Paradigm CC-290
Rear and Side LR Yamaha IC-800 Speakers (ceiling)
Subwoofer Paradigm DSP-3200
My living area is hardwood Grey-Ironbark floors with no coverings. This is the first limitation - no carpets on the floors (Our two old cats use them to sharpen claws and as a sick bay). I know from reading extensively on audio acoustics that this is a big downer. If its a really big downer I might, I say might, be able to convince the wife and manage the cats (if you have a cat you would have laughed at this comment).
There are windows with heavy curtains to the floors. See the diagram below. On the right side looking from the TV is a long wall with several doors, a cabinet and one large canvas painting. The kitchen is all hard surfaces and pretty difficult to do much about, except about 500mm above the cabinets to the ceiling.
I would love some suggestions on how to improve the rooms acoustics.
zanlation is offline
Paradigm Cc 290 V 6 Center Channel Speaker , Yamaha Ns Ic800 In Ceiling Speakers Pair White
