New Home Build, wandering about screen placement in basement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-26-2013, 09:27 AM - Thread Starter
EricK11's Avatar
I have been reading these forums for the last couple months as we have been progressing on the home building process with the plan of putting a home theater/rec room in the basement so the theater won't be completely closed in style but I would still like to have a 7.1 system with a projection system. I have been toying around with the idea of having a plasma and a projector setup, with the screen coming down when it is time to watch a movie or the big game, or should I bother with this and just go with the projector setup.
The question now is where to put the screen in the room as the architect has put the screen against the widest room, with the back part of that room open, where I am wandering if it would be better against either the shorter flat wall, or pushed out from the half-hex area at the other end of the room where I could then possibly hang the TV in the back part of the nook and also place the center channel and front surrounds on the side of the screen. Also planning on taking the windows out of the nook area as well if I was to put the screen in that area. The other question is if I should put in a 16:9 or 2.35:1 screen
Any thoughts or recommendations would be greatly appreciated.
Eric
EricK11 is offline
post #2 of 2 Old 08-01-2013, 04:44 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3039 Post(s)
Liked: 2972
You could go with a smaller plasma / larger electric screen. The wall shown with the screen on it now probably works as well as any. 16:9 or 2.35:1 sort of depends on what you like to watch the most. Where are you located ( doesn't say under your signature ) ? If possible, if there are AVS forum members near you with home theaters / media rooms, it doesn't hurt to see other peoples setups for ideas. Craig
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
