Need to run additional wire behind finished wall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-26-2013, 01:35 PM - Thread Starter
jbrady3324's Avatar
Quoted: 99 Post(s)
Liked: 39
I recently bough a condo that is already pre-wired for most things, however I need to run a few additional wires behind the wall where wires already are run (hdmi, etc). Is there a proper way to do this without having to do any damage to the wall?
LG 65OLEDC7P
Pioneer KRP-500m
Next Level Acoustics HDMONs LCR, CI-IC44A In-Ceilings, CI-HV10 subwoofer
M&K LCR-750s, M-4T Surrounds, V1250thx subwoofer - FOR SALE!
Wharfedale Denton 80th Anniversary
Sennheiser HD800 & Grado PS1000 headphones
jbrady3324 is offline
post #2 of 8 Old 07-26-2013, 01:51 PM
Bacon13's Avatar
Liked: 39
Exactly what wires are you running and how far?
Do you need to go vertically only or horizontal as well?
Bacon13 is offline
post #3 of 8 Old 07-26-2013, 02:15 PM - Thread Starter
jbrady3324's Avatar
Quoted: 99 Post(s)
Liked: 39
I will be running 1 HDMI and maybe a few additional speaker wires. I would need to go diagonal.
LG 65OLEDC7P
Pioneer KRP-500m
post #4 of 8 Old 07-26-2013, 02:37 PM
neo_ny's Avatar
I have a similar issue as well .. need to run additional speaker wires into existing wiring in the wall .. any input on how best to accomplish this?
neo_ny is offline
post #5 of 8 Old 07-26-2013, 03:03 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Search for "wire fishing". And nothing will go diagonal, so to speak. There are techniques to go horizontal and vertical. How far and what obstructions are in the way will determine the difficulty factor.
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #6 of 8 Old 07-26-2013, 06:52 PM - Thread Starter
jbrady3324's Avatar
Quoted: 99 Post(s)
Liked: 39
So diagonal is possible, but it is very difficult?
LG 65OLEDC7P
Pioneer KRP-500m
post #7 of 8 Old 07-26-2013, 08:10 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Anything is possible. It's just a whole lot easier to go vertical then horizontal or horizontal then vertical.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #8 of 8 Old 07-26-2013, 08:24 PM
Sweetmeat's Avatar
Quoted: 307 Post(s)
Liked: 74
If you only have to go vertical, its very easy. You just cut 2 holes in the wall in between two studs, so you don't need to drill through the studs.
If you also have to go horizontal, you're guaranteed to have to drill through studs and put a hole in your drywall about every 16". Get a long enough drill bit that can make it through your stud by drilling at an angle into the stud (from front to back of stud, front being closest to drywall). Use the fishing tape to pull your wires through the drilled hole to the next drywall hole (which will be next to the next stud).
Patching the holes in the drywall is easy, but getting the paint to match may be more difficult.
PN59D8000 and JVC RS420 with Elite 120" screen
Receiver - Yamaha RX-A3060, WXA-50 MusicCast Amp for Zone 2
Front - CM9, Center - CMC2, Side Surrounds - DS3, Rear Surrounds - CM5, Front/Rear Atmos - CCM663, Subs - PB12+ and PB13 Ultra
Remote/Streaming Media Players - Harmony Elite, Apple TV 4, Nvidia Shield Pro - use with HDHomeRun Connect/Extend and Plex
Sweetmeat is offline
